Arctools won't run on my Arnova 7c G2
Ranmore
2011/10/27 - 22:39
Arctools 0.53 (downloaded via Appslib) won't run on my new Arnova 7c G2
I get the following error whenever I try to start it: "The application Arctools 0.53 (process com.arctablet.arctools) has stopped unexpectedly. Please try again."
I tried rebooting after installation but the problem remains.
Any ideas?
Thanks Received: 3177
2011/10/27 - 23:56
Arctools currently does not support the Arnova 7c G2. We hope to implement it soon when we get a device. Will keep you posted thru Arctablet Blog and Forum.
Zenuno
Portugal
Forum Posts: 17
2011/10/28 - 02:26
I'm already waiting... lol
Arnova 7c G2
Zenuno
Portugal
Forum Posts: 17
2011/11/07 - 01:23
Hi.
I install arctools 0.57 and works fine but when i try to install the apps it says "error 28: Cannot create temporary directory"
"error 20: fail to copy file"
Any sugestion?
Thanks.
Arnova 7c G2
danisarbu
Forum Posts: 13
2011/11/07 - 04:04
Same problem, arctools working but no apps...
2011/11/07 - 08:42
ArcTools in latest versions (0.57 and up) has been fixed to run on the Arnova 7c G2, but is not yet able to install the Android Market. This feature will require a custom firmware that is currently in the works, and should be released soon.
Stay tuned.
danisarbu
Forum Posts: 13
2011/11/07 - 08:48
Ok, thanks.
Zenuno
Portugal
Forum Posts: 17
2011/11/07 - 18:38
Ok. thanks
Arnova 7c G2
ryanseager
2011/11/29 - 01:40
Hi, any news on the android market access for the 7c G2, I can't wait to be able to use this tablet to its potential and not just the minimal and somewhat lame apps on the appslib, I think the only app on the appslib worth downloading is the arctools.[Image Can Not Be Found]
amwilby83
2012/01/07 - 12:07
Hi guys, i got this tablet yesterday and found it wasnt connected to the andriod marketplace which was a shock. I understand this Arctools will make that happen. Do you know when a working version will be ready for the 7c g2
2012/01/07 - 12:39
ArcTools is currently being updated to work with the current Arnova 7c root method  or a custom firmware (to be released). We'll post an update when it's ready.
benhum
2012/01/07 - 19:00
Great stuff - as my attempt at getting Market onto my 7cG2 resulted in a brick (but I can still get into recovery), I assume the custom firmware will give it life again!
jameslewisuk
Forum Posts: 79
2012/01/22 - 11:58
Are we any closer to having a working Arctools for the 7c G2 ?
I have rooted my device and tried various versions of the google apps files, whatever I do I still run in to the same issue of "Can't establish a reliable data connection to the server" when trying to add my google account.  I've tried the simple method of "sideloading" the apps from SD card, and also tried putting the apps in to system/app and setting permissions etc.
I feel there must be something else in the stock firmware that's stopping it from connecting/adding the google account ....
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/22 - 14:20
I once got it to connect with google servers, after switching from a @gmail.com mail adress to @googlemail.com, but then it failed downloading apps (a google search showed it was a common issue among many devices, but I couldn't fix it)
Now where I got a working system.img, I may give it a try again.
ahhh... and the devices aren't "google certified", that's why no android market in stock firmware.
jameslewisuk
Forum Posts: 79
2012/01/26 - 21:44
Whatever I do I still can't get it to connect with servers.... I installed all the APK's manually to system/app
56 Guest(s)
Devices in use: Desktop (48), Phone (8)
cimoral
merlin077
nrod
midnight-gr
Pajaro047
trroll171717
