arctools setup wizard loop - restore factory settings via a key press combination at boot up??
hilltophousemjh
Forum Posts: 13
2012/03/09 - 08:43
Hi
I've recently installed Arctools and managed to get into a 'Setup Wizard' loop where it force closes and then starts again. I'm not able to get to any other settings/options etc as it boots straigt to thte force close screen.
Are there any ways to get to the restore factory settings via a key press combination at boot up (i.e. the screen you could normally get to from the Settings options)
Thanks Received: 3177
2012/03/09 - 11:50
Have a look at Nano and DanielVd custom firmwares, these will help you fix your device.
You'll first need to install tremendo's recovery using adb fastboot to be able to flash one of these firmwares.
Refer to the custom firmware forum topics for installation details.
Thanks Received: 268
2012/03/09 - 13:25
You can also do a simple wipe if you want to keep your stock rom.
fastboot -w is the command
You cand find out more here
http://www.arctablet.com/blog/forum/arnova-7c-g2/what-is-adb-and-fastboot-how-to-install-and-use/
hilltophousemjh
Forum Posts: 13
2012/03/10 - 22:06
Thank you globula_neagra this worked a treat and helps boost my confidence in trying the custom roms as per Admins comment, but thats for another day. Thank you both.
55 Guest(s)
Devices in use: Desktop (47), Phone (8)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
