2013/01/30
Hi all.
Im after a bit of help. Got myself one of these lovely tablets, really happy with it. Got an O2 data sim, and stuck it in, while turned off. Tablet sees the sim, but I cannot seem to connect to anything... Wifi works great at home connected to sky. But I just cant connect to the big wide world when out and about.
I chose 02 , as best coverage for me, but at the moment I cant seem to get anything. I cant send text either so who knows?????
Any help anyone could give would be really appreciated.
Many Thanks
First share what OS version you have settings/about device
Android Version
Kernel version
Build Number
I would recommend to back`up your system, then install a custom firmware which will give you more access to different APN`S.
If you don`t want a custom firmware you should be able to add manually the APN
First find the APN used by O2, than go to:
settings/wireless and networks settings/ mobile networks/access point names
48 Guest(s)
Devices in use: Desktop (43), Phone (5)
