After instaling market android doesnt star
chulis
Forum Posts: 12
2012/05/05 - 12:19
Good moorning, I had a big problem after installing market the devide does not start any more, I press power on then I can see  ARNOVA and then ANDROID apears and desapears for all time and no finish start  ¿what can I do? sorry for  my english.
Thanks Received: 264
2012/05/05 - 12:39
you bricked your device
how did you installed the market
did you rooted your device before ?
i can help you to recover your device
chulis
Forum Posts: 12
2012/05/05 - 13:28
My device is not rooted and I insntalled market adding the carpets in the memory and then in instalation aplication android
2012/05/05 - 13:35
you can`t add them without root`ing the device, and therefore you bricked something.
if you want i can help via team viewer
you will need anyway to instal java sdk, android sdk if you want to recover your device
chulis
Forum Posts: 12
2012/05/05 - 13:38
How can i install java sdk and android sdk can we make all now?
2012/05/05 - 13:40
it would be easy if you let me in your computer
install team viewer and send me a pm with the id and password.
chulis
Forum Posts: 12
2012/05/05 - 13:47
sent mp dont you need msn messenger for talking?
sandro90
2012/07/24 - 17:48
Hello there,
I just had a similar problem with my Arnova 7c G2.
My first question is: did you solve the problem that you had?
If yes, is there any chance to get some help solving the problem?
Thanks very much.
2012/07/24 - 20:20
Yes there, you need to:
1. get the tablet in fastboot mode
2. install the drivers
3 use the command fastboot -w to get the tablet in the factory state.
4. use the command fastboot continue
so in this way the tablet will bot normally.
This are the steps, there are explanation on the forum (more detailed), and also links for the drivers, tutorials
sandro90
2012/07/25 - 14:47
I have tried to do the first step but I could not manage to do it because at some point it says that I need to connect the table to the PC in DEBUG mode going to Settings –> Applications –> Development –> check the “USB Debugging” box. The problem is that I am not able to turn on the table so I am not able to connect the table in debug mode. Have you got any other solution?
The tutorial which I am following the instructions is the one below.
Any good?
Thanks very much.
2012/07/25 - 16:10
reset the tablet using the hole from the back
connect it to the pc, you should see the lights flashing
press in the same time, the power button and the volume key minus (that lowers the volume), you should hear a sound comming out from your pc, and the driver wizzard should appear
if you have windows xp, it will be a pain in the ass to install the drivers
first step try the method offered by windows, if it does not work, you will find here on the forum, in the arnova 7c g2 android dev a topic called usefull stuff, there is a tool there called superoneclick, which has an option to force install the drivers.
lets presume that you will manage to get the tablet in fastboot mode and install the drivers
using the tutorial that you posted, you will use the command fastboot
so you will check with the command fastboot devices, to see if the arnova is connected, and the drivers are installed, if you get a positive result, you only need to type after that
fastboot -w
fastboot continue
and you should be able to use the tablet again.
sandro90
2012/07/25 - 17:40
Thanks very much, it has perfectly worked Wink.
54 Guest(s)
Devices in use: Desktop (52), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
