Accessing a flash drive via the usb port
lostpenguin
United Kingdom
2012/04/17 - 16:07
Anyone know how I can access a flash drive (pendrive) - I have the microusb to normal female usb connector but the Arnova cannot see it. I am running the 13b rom update.
Thanks Received: 268
2012/04/17 - 17:01
i dont know if arnova supports that, wait and see, maybe someone else tried to do the same thing.
neo-b
2012/05/08 - 11:58
Yes, Arnova support the OTG. I've tested, and it works fine...you can acces the pen drive with rootexplorer, through this path , /mnt/udisk.
the problem, is when ou want to unmount and unplug your flashdrive...the arnova restart by itself...any solution??
people talk about the kernel with the "ums" enabled...
2012/05/08 - 13:10
we can`t add that because we don`t have the source files
arnova has not released the android, and kernel sources.
46 Guest(s)
Devices in use: Desktop (41), Phone (5)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
