7c g2 has ...........mha battery?
sanaldi
Forum Posts: 17
2012/08/12 - 02:50
What is our battery's mha?
Thanks Received: 268
2012/08/12 - 12:37
4200 mah
sanaldi
Forum Posts: 17
2012/08/12 - 16:17
Is it a problem that we use it while charging?
2012/08/12 - 16:51
no
sanaldi
Forum Posts: 17
2012/08/12 - 23:20
i want to use it as a navigator but it is enough to power it from the car?
2012/08/13 - 10:58
yes, it is
sanaldi
Forum Posts: 17
2012/08/13 - 11:10
globula_neagra said
no
Ok thank you so much
sanaldi
Forum Posts: 17
2012/08/14 - 18:05
On user guide it says that it should not be charged via a usb port. Why? Even if i use a 2 amper usb charger?
2012/08/14 - 19:12
because it charges very slow
i don`t remeber what is the exact amperage of the charger, i think is somewhere between 500mili amps and maximum 1 amp
maybe you should search for a nokia car charger :)
sanaldi
Forum Posts: 17
2012/08/15 - 04:22
The original charger is 2 A. I think a nokia charger wont be enough for gps consumption
Currently Online: ri9000, hamishduke
69 Guest(s)
Devices in use: Desktop (62), Phone (9)
hamishduke
squal
squalangel
anqilan456
havetoregister
werasler
