3g - Can receive SMS but not send SMS ?? Help please !
ra2000
Forum Posts: 32
2012/03/06 - 19:11
Thanks Admin & globular_neagra - I've downloaded ES Explorer and found the apns-conf.xml file and read it using ES Note Editor.
Scrolling through there is no mention of Vectone, although I have the green radio button showing on Settings/Wireless & Networks/Mobile Networks/Access Point Names.
Should Vectone be added to that list once I create a New APN, or do I have to somehow add it manually - and if so how?
Many thanks in advance
Thanks Received: 268
2012/03/06 - 19:59
I have lebara, and i can send and receive sms
the apn`s config contains the general carrier settings for the internet acces, not sms
you should try another rom, or a factory reset of the device.
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/03/24 - 12:55
Hmm... try this.
Download the following files:
http://downloads.nanolx.org/apns-conf.xml
http://downloads.nanolx.org/spn-conf.xml
push both files into phone and reboot:
adb push apns-conf.xml /system/etc/
adb push spn-conf.xml /system/etc/
adb reboot
Check if it works.
ra2000
Forum Posts: 32
2012/03/24 - 14:01
Thanks for the info setialpha ; I have clicked on the links provided but although they show what goes into the files I do not know how to create the XML file - can I just copy everything to a .doc file and change the extension to XML?
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/03/24 - 15:35
right-click -> save as
ra2000
Forum Posts: 32
2012/03/25 - 01:18
Had fun and games with adb getting eror: device not found so went through the instal procedure over and again and checking on help forums. Device was found with fastboot but adb but now got adb to recognise device and did the push but get :
failed to copy 'apns-conf.xml' to '/system/etc//apns-conf.xml':  Read-only file system
and the same with spn-conf.xml.  Any ideas ?
EDIT :  Got the answer after trial & errors from other sites.
adb remount
adb reboot
now to see if texting works ....
ra2000
Forum Posts: 32
2012/03/25 - 03:22
Tried the messaging service but got "Error Code : 21"
From another web site it seems that this means:
"Short message transfer rejected" This cause indicates that the equipment sending this cause does not wish to accept this short message, although it could have accepted the short message since the equipment sending this cause is neither busy nor incompatible.
Thoughts ?
2012/03/25 - 04:51
First, be sure that your device is connecte, check this by using the command
adb devices if you get a positive answer, googlefor qtadb and use it to copy the files in the desired location
ra2000
Forum Posts: 32
2012/03/25 - 15:45
Thanks globular_neagra .
In answer, I do get a positive response back from adb devices - at first I was getting a device not found message and when I went through the adb instal procedure with Super One Click then adb responded to adb devices by giving me the serial number back.
I have had no joy trying to instal Qtadb - when I start it it opens with an error message "there was an error checking for updates" and then clicking on Apps gives another error message saying it could not find aapt. Despite following the error instruction of downloading and putting in the same dir as adb and clicking refresh (which contradicts the FAQ telling me to place it to /sdk/tools) it still returns the same error message.
Anyhow, I did install Qtadb by trying :
adb remount
adb push ./"qtadb.apk" ./system/app
adb reboot
and this worked for installing Qtadb and when I open this app I select "Start service" then I open Messaging but I still get an Error code:21 each time I attempt to send a text message.
Cannot understand what is wrong
2012/03/25 - 21:25
i can help you via team viewer if you want.
ra2000
Forum Posts: 32
2012/04/01 - 18:41
Thanks for the offer - but it's not the PC that has a problem but the tablet.... or can teamviewer be installed on the tablet?
As said, I managed to instal Qtadb by the method above but it didn't help with Messaging.
Currently Online: hoholms
44 Guest(s)
Devices in use: Desktop (39), Phone (6)
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
xstouf
