2012/10/14
Hi allÂ
hope someone can help. a week ago my arnova 7g2 turned on but gets stuck at the arnova screen blinks a few times but wont get past that. i am confused about the rockchip which i tried but cant get the driver to install. i am not sure if i used the right one when it gets to the 64 bit then vista then it says nothing found . i am looking for the rk2918 Â only because i assume that the arm cortex a8 is the same not sure. anyways i am a newbe at this so if someone could help me in detail i would appreciate it. also i downloaded the artools firmware to get google play shortley b4 that. and my computer says it recognizes the arnova driver but i cant see it when i look at the usb connections. thanx in advance. Â
51 Guest(s)
Devices in use: Desktop (44), Phone (7)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
