APPLICATIONS AND ESENTIAL TOOLS
APPS
GAPSS GB WITH MARKET 3.4.4
Link : http://www.mediafire.com/?c95iicwc6d7uwas
ADOBE FLASHPLAYER working on Arnova (the player delivers the flash content in stock browser and some other applications lke bbc iplayer.)
Link : com.adobe.flashplayer.1031850360.apk
FILE EXPERT, this is the last free version that has root explorer and mounting options (in market these options are available now, only on the paid version )
Link : FileExpertLatest.apk
 STOCK ROMS - CUSTOM ROMS -DRIVERS - ROOT TOOLS
Recovery Image:
Link : http://www.nanolx.org/downloads/trenano-recovery-nosd.img Credits to sethialpha and other developers.
STOCK ARNOVA ROM
Link : http://www.mediafire.com/?qfp502ij2csle2e
SUPER ONE CLICK ROOT TOOL
Link : http://www.mediafire.com/?2a2ttwo2ecyieet
TUTORIALS
What is ADB and Fastboot ? HOW TO INSTALL AND USE.
Link :Â http://www.arctablet.com/blog/forum/arnova-7c-g2/what-is-adb-and-fastboot-how-to-install-and-use/
BEST VIDEO FORMAT FOR ARNOVA 7C G2
Link : http://www.arctablet.com/blog/forum/arnova-7c-g2/best-video-format-for-arnova-7c-g2/
To be updated
Beats Audio from original thread, when a working version on arnova will be available a link will appear here.
BEATS AUDIO FOR ARNOVA (this works only on 7c g2, not tested on other arnovas)
You can feal the difference with high end headphones (even so, with some casual headphone you should feel some difference)
It must be flashed by recovery
http://dl.dropbox.com/u/17062920/fla...%20CM7LGO1.zip
Enjoy
ONLY FOR ROM DEVELOPERS
BUILD.PROP TWEAKS
Data Tweaks Increase download/upload/3G speeds
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.ril.hep=1
ro.ril.enable.dtm=0
ro.ril.hsdpa.category=8 (or 10,12,14) Still looking for more of these though.
ro.ril.enable.a53=1
ro.ril.enable.3g.prefix=1
ro.ril.htcmaskw1.bitmask=4294967295
ro.ril.htcmaskw1=14449
ro.ril.hsupa.category=6
POWER SAVES
Allows the phone to sleep better
ro.ril.disable.power.collapse=1
Saves power when phone is sleep
pm.sleep_mode=1
Allows your wifi to scan less, saving more battery
wifi.supplicant_scan_interval=150 or 180 (your choice)
Helps Scrolling Responsiveness
windowsmgr.max_events_per_sec=150
Increase overal touch responsivenss
Debug.performance.tuning=1
Video.accelerate.hw=1
SYSTEM TWEAKS
Forces your home launcher into memory
ro.HOME_APP_ADJ=1
Change the Dalvik VM heap size
dalvik.vm.heapsize=64m can use 24, 32 is default, 48, 64
To disable usb debugging popup
persist.adb.notify=0
Fix some application issues
ro.kernel.android.checkjni=0
Render UI with GPU
debug.sf.hw=1
Source
It not applys to the arnova do to the construction mode and position of the hardware (i tested all the things posted till now)
Arnova gets at 30 (or higher)Â degrees celsius only when is connected to the pc or when you are using it for gaming.
globula_neagra said
ONLY FOR ROM DEVELOPERSBUILD.PROP TWEAKS
ro.ril.hsxpa=1
ro.ril.gprsclass=10
ro.ril.hep=1
ro.ril.enable.dtm=0
ro.ril.enable.a53=1
ro.ril.hsupa.category=6Â
POWER SAVES
ro.ril.disable.power.collapse=1Saves power when phone is sleep
pm.sleep_mode=1Allows your wifi to scan less, saving more battery
wifi.supplicant_scan_interval=150 or 180 (your choice)Helps Scrolling Responsiveness
windowsmgr.max_events_per_sec=150Increase overal touch responsivenss
Video.accelerate.hw=1SYSTEM TWEAKS
ro.HOME_APP_ADJ=1Change the Dalvik VM heap size
dalvik.vm.heapsize=64m can use 24, 32 is default, 48, 64To disable usb debugging popup
persist.adb.notify=0Fix some application issues
ro.kernel.android.checkjni=0Render UI with GPU
debug.sf.hw=1Â
Source
http://forum.xda-developers.com/showthread.php?t=1367082
Another collection of build props and Tweaks that should be tasted
Using a cpu governor like SetCPU, CPU Master you can keep your device processor at the frequency 480 MHz and the maximum 800.
Why?
At the frequencies 480,320,245,122 the cpu uses the same power and voltage so it is more efficient to set the minimum frequency at 480 MHz, in this way you will obtain a more responsive device.
If you want always want performance you can set the cpu always at 800 MHz but the buttery will drain faster.
This rule applies only for the processors under msm 7x72 family.
Install this .reg (http://goo.gl/wCCz) which allow you to open the Windows Prompt in the chosen folder by command in.
New bbc iplayer with subtitles in english and optimization on the video playback
Dl link: http://www.2shared.com/file/MWs98J1-/bbciplayerandroid13014.html
Full version of flas player 10.3 working with bbc iplayer (flash player settings now working)
Dl link : http://www.2shared.com/file/Kty-tXLu/adobe_flash_player_11_v1101153.html
New Xperia home Screen from SOny Xperia S
http://forum.xda-developers.com/showthread.php?t=1557091
Download Link
Home app http://www.mediafire.com/?8l4ybykvqrzs4wt
Clock Widget http://www.mediafire.com/?kldd6llfoyrhuq8
Widget Picker (you can not use clock widget without this) http://www.mediafire.com/?c4o2uwuwb3ijau5
Build Prop EDITOR
https://play.google.com/store/apps/details?id=de.bwulfert.buildpropedit
http://forum.xda-developers.com/showthread.php?t=1542949
MIUI FILE EXPLORER !!!
http://forum.xda-developers.com/showthread.php?t=1523691
Download Link
http://www.mediafire.com/?lfeti6lrbfbqdak
Android Screen Cast
Link: http://www.mediafire.com/?h6ga000ancaa06i
Required programs, android sdk, java sdk, Usb drivers for your device.
http://www.unlockroot.com/ Another rooting tool and driver installer
http://www.mediafire.com/?3fnfr93dkrp37c1
Gps.conf files for the hole world
Just copy the gps.conf that you need in system/etc/gps.conf (mount system as read write before)
http://forum.xda-developers.com/showthread.php?t=1579981 Source.
60 Guest(s)
Devices in use: Desktop (49), Phone (11)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
