Stock recovery.img
kuro01
Forum Posts: 12
2012/05/03 - 20:15
Can anybody upload stock recovery image file? (need it for warranty service)
hilltophousemjh
Forum Posts: 13
2012/05/03 - 22:20
I'm happy to help IF I can! I have standard factory unit as I've been holding out any upgrade. However, I do not have the knowledge on how to create an image. I do have most the tools installed on my PC as per the guides here, so if you are able to advise on the process to back the orignal rom, I'll try and get the time to do so.
kuro01
Forum Posts: 12
2012/05/04 - 09:11
Try this location: /system/bin/recovery.img (in my MSI it's located here)
You can copy this file to your /sdcard with ES File Manager for example
and other way
How To Backup Your Android Phone’s Boot, Recovery And System Partition Images
http://www.addictivetips.com/mobile/how-to-backup-your-android-phones-boot-recovery-and-system-partition-images/
Dumping your device's ROM
The simplest method to dump your devices ROM, is to use the 'romdump' program, there is no need to root your device, or install SuperUser as the installer comes with it's own root exploit
dumps the BOOT, RECOVERY and
SYSTEM partitions to your SDCARD
http://android.podtwo.com/romdump/
Thanks Received: 264
2012/05/04 - 11:50
i will try this day, if hilltophousemjh agrees to enter in his computer and try to get the stock recovery from his stock rom via team viewer
kuro01
Forum Posts: 12
2012/05/05 - 10:49
Any news?
2012/05/05 - 14:06
I`am right now on person pc`s ,that has the stock rom and recovery image on his device, i hope i will recover from him.
kuro01
Forum Posts: 12
2012/05/05 - 19:19
I hope dump finished successfully?
2012/05/05 - 19:51
well i dumped the rom, but the boot and recovery image where not extracted, i dont know why, only the system file was extracted
kuro01
Forum Posts: 12
2012/05/05 - 20:05
here is written that exists Alternative Method of dumping just for recovery and boot images.
Could you  try it?
hilltophousemjh
Forum Posts: 13
2012/05/05 - 20:31
Hi all, Had a quick try today and got the below,I think I missed a root action. I'm not going to get chance for a few days now but any advice to resolve?
C:\Program Files\Android\android-sdk\tools>adb push install /data/local/
1621 KB/s (1098865 bytes in 0.662s)
C:\Program Files\Android\android-sdk\tools>adb shell chmod 04755 /data/local/ins
tall
C:\Program Files\Android\android-sdk\tools>adb shell /data/local/install
Android ROM dumper v0.72b
(c)2010 Sebastian404
  • Android local root exploid (C) The Android Exploid Crew
    [+] Using basedir=/data/local/tmp, path=/data/local/install
    [+] opening NETLINK_KOBJECT_UEVENT socket
    [+] sending add message ...
    [-] sendmsg: Connection refused
    [1]   Segmentation fault      /data/local/install
  • C:\Program Files\Android\android-sdk\tools>adb shell romdump
    romdump: permission denied
    2012/05/05 - 20:34
    i thinkg i made `it, wait 1 hour please 🙂
    2012/05/05 - 21:21
    k, guys, i will test a stock recovery image in 15 minutes, if it is good, i will give you a download link
    2012/05/05 - 21:46
    stock recovery image 🙂
    download link http://www.mediafire.com/?gr24jl3058sb2wt
    bambyzas
    2014/12/05 - 17:38
    mayby who have full rom backup from archos platinum 97 HD
    58 Guest(s)
    Devices in use: Desktop (46), Phone (12)
    cutierogue
