porting cyanogen (info thread)
alex
Forum Posts: 252
2012/02/10 - 11:27
Am i right in thinking that the system and boot images are the same in all rk29s as i am trying to make a rom for the 9g2 and i think the system and boot images i have previousley downloaded are corrupt
Thanks Received: 3171
2012/02/10 - 11:30
Alex, the 7cG2 is not Rockchip based but Qualcomm MSM7627 800 MHz CPU, which is a totally different beast Wink
alex
Forum Posts: 252
2012/02/10 - 11:53
Surprised oh dear 😛 i presumed all g2s were rockchip lol thanks anyway
tremendo
Forum Posts: 42
2012/02/10 - 14:45
by the way, if someone wants to do a proper relase of recovery they can look at the correct key codes under the advanced menu and substitute them in the source tree i will gladly provide (3.5 gigs uncompressed...) i built on an ubuntu 10.04 box
i tested the backup and restore function and it seems to have worked flawlessly; don't try to flash the userdata partition with the userdata.img generated by the recovery, though -- it wont work.  i think it gets exported in a different filesystem, it would be nice to be able to convert them.... mostly because fastboot is more reliable
i hope to have the time to reflash my cyanogenmod port in a couple of days just to try and see if adb logcat provides any clues regarding the boot failure... if you're feeling bored feel free to do it and send me the logcat..
jameslewisuk
Forum Posts: 79
2012/02/10 - 23:41
How do you get in to this recovery when the phone boots?
tremendo
Forum Posts: 42
2012/02/11 - 12:46
you cant as far as i know... youneed to flash a stock or cfw boot and image and then you can boot and go to settings/info/updates... and then it boots into it
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/11 - 19:08
tremendo cuold you port as the same method also for this boot: http://www.mediafire.com/?qhqogru1izzgr7q
tremendo
Forum Posts: 42
2012/02/13 - 04:18
nothing works, but at least it boots now =)
cm.jpgImage Enlarger
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/13 - 07:33
you are a genious
cyanogen is not a rom, is a lifestyle, please share to us
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/13 - 17:52
I compiled a new port, if someone want to trying? not all works
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/03/28 - 22:11
tremendo could you upload working boot.img?
105 Guest(s)
Devices in use: Desktop (91), Phone (14)
heftpflaster
rk.13
