porting cyanogen (info thread)
tremendo
Forum Posts: 42
2012/02/09 - 15:27
Starting this thread where i am going to post various notes i come up with while trying to port cyanogen.
I've built a clockwork recovery image that i posted on another thread if you want to try it... im not feeling as adventurous until i have another backup of my stock recovery as i dont fully trust the romdump process... also the fact that you cant apparently start recovery with a keypress at boot and must start it from a running instance of the full UI kind of makes the point moot... bit of pointless to have a clockwork recovery that you cant start if you brick your device, right?
anyway the first problem in porting cyanogenmod is going to understand which proprietary files go where.. so i am posting a list of devices that share the yamato firmware to later see whether they have a similar board.
here goes, list of devices that cyanogen's been ported too and also have the yamato firmware
zte/v9/unzip-files.sh:unzip -j -o ../../../${DEVICE}_update.zip system/etc/firmware/yamato_pfp.fw -d ../../../vendor/zte/$DEVICE/proprietary/
zte/blade/unzip-files.sh:unzip -j -o ../../../${DEVICE}_update.zip system/etc/firmware/yamato_pfp.fw -d ../../../vendor/zte/$DEVICE/proprietary/
samsung/tass/extract-files.sh: vendor/__MANUFACTURER__/__DEVICE__/proprietary/etc/firmware/yamato_pfp.fw:system/etc/firmware/yamato_pfp.fw \\
htc/supersonic/unzip-files.sh:unzip -j -o ../../../${DEVICE}_update.zip system/etc/firmware/yamato_pfp.fw -d ../../../vendor/htc/$DEVICE/proprietary
htc/liberty/extract-files.sh:adb pull /system/etc/firmware/yamato_pfp.fw ../../../vendor/htc/$DEVICE/proprietary
htc/vision/vision.mk: device/htc/vision/firmware/yamato_pfp.fw:system/etc/firmware/yamato_pfp.fw \
htc/bravoc/unzip-files.sh:unzip -j -o ../../../${DEVICE}_update.zip system/etc/firmware/yamato_pfp.fw -d ../../../vendor/$MANUFACTURER/$DEVICE/proprietary
htc/saga/unzip-files.sh:unzip -j -o ../../../${DEVICE}_update.zip system/etc/firmware/yamato_pfp.fw -d ../../../vendor/$MANUFACTURER/$DEVICE/proprietary
commtiva/z71/device_z71.mk: vendor/commtiva/z71/proprietary/etc/firmware/yamato_pfp.fw:system/etc/firmware/yamato_pfp.fw \
htc/espresso/extract-files.sh:adb pull /system/etc/firmware/yamato_pm4.fw ../../../vendor/htc/$DEVICE/proprietary
htc/passion/unzip-files.sh:unzip -j -o ../../../${DEVICE}_update.zip system/etc/firmware/yamato_pfp.fw -d ../../../vendor/$MANUFACTURER/$DEVICE/proprietary
It looks like the zte v9 is the only tablet... all devices are msm7227 ; it might be needed to use the kernel from the auroracode branches... will keep looking
tremendo
Forum Posts: 42
2012/02/09 - 15:38
These are the only files that are presnt on a zte v9 but not on the c7g2
remote object '/system/bin/akmd2' does not exist
remote object '/system/etc/ti_gauge.bqfs' does not exist
remote object '/system/etc/ti_gauge.dffs' does not exist
remote object '/system/lib/libdll.so' does not exist
remote object '/system/lib/libloc.so' does not exist
remote object '/system/lib/libOmxQcelpDec.so' does not exist
remote object '/system/lib/libOmxEvrcDec.so' does not exist
posting it here so i can later look it up and see what's not going to be working =)
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 15:40
This is the cyanogenmod port for our tablet: http://www.mediafire.com/?dorpdubo5z1cqnk.
It will work as soon as we will have custom working recovery, before that it is not possible to flash this rom 🙁
tremendo
Forum Posts: 42
2012/02/09 - 16:19
libloc.so is not present but libloc-rpc.so is ? Maybe this is the problem with localization in the  current CFW build? might have to try reflashing a stock system...
tremendo
Forum Posts: 42
2012/02/09 - 16:20
Daniel, that's not cyanogen, that's just the recovery. and i posted that file to another thread... please try to stay on topic
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 16:28
i am sorry i post the wrong url, i have to upload it again because i miss to login on mediafire 🙁
THIS IS THE RIGHT URL: http://www.mediafire.com/?qb1bauavw1y33fd
I made a port from the commtiva z71 cm, it will have some bugs, but now i can't test on my tablet because is on assistence centre.
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 18:54
The tremendo recovery work, but the keys are not configured:
Image Enlarger
tremendo
Forum Posts: 42
2012/02/09 - 20:48
much to my surprise the first build of the msm7627 port of cyanogen completed! Who is brave enough to flash it? I'd do it first but i must find a way to back up my data and cache partitions first because they need to be wiped...
if you know how to do a bitwise copy of /data please let me know.. i'll try later
tremendo
Forum Posts: 42
2012/02/09 - 20:49
whoa, daniel, davvero it works? i'll try changing the keymaps later.
i clearly have no idea what i'm doing...
thanks for testing! how did you start it?
I'll be uploading the boot and system partitions if you're feeling brave.
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 20:53
I'll ben uploading the boot and system partitions if you're feeling brave
upload 🙂
tremendo
Forum Posts: 42
2012/02/09 - 20:55
i spoke too early, not all of /system compiled...
*** No rule to make target `out/target/product/msm7627_fw8918/obj/lib/libaudio.so', needed by `out/target/product/msm7627_fw8918/obj/SHARED_LIBRARIES/libaudioflinger_intermediates/LINKED/libaudioflinger.so'.  Stop.
from what i gather this should be related to the DSP in cyanogen... i'll try and and delete it from the makefile
i'll have to investigate. thhe boot partition compiled though... and so did vpnservices.apk which i what im after..
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/09 - 20:58
You could upload boot.img atleast. I always have mine to fix.
tremendo
Forum Posts: 42
2012/02/10 - 00:31
setialpha: http://www.mediafire.com/?kvge0aclbj473n4 is the boot.img
ill try to see if i can do a complete build before i look at whats wrong with cw-recovery
tremendo
Forum Posts: 42
2012/02/10 - 06:24
ok here is the build output:
userdata.img : http://www.mediafire.com/?80843lv09m6igq5 /suppose this must be flashed on data partition, your guess is as good as mine)
system.img : http://www.mediafire.com/?r3q9x4xaeopb7rf
boot.img : http://www.mediafire.com/?kvge0aclbj473n4 (this is the same file as before, i will check for differences but dont expect to find any)
and again recovery.img with non functioning keys. http://www.mediafire.com/?kvge0aclbj473n4
if you're brave enough to test dont forget to wipe your data partition (and maybe flash it with userdata.img)
***WARNING: it doesnt work*** it stays stuck at the "A N D R O I D" screen
these images are only good for extracting bits and pieces (I'm thinking of vpn services)
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/10 - 08:40
Tremendo your recovery works fine, when you enter into recovery you have t o press 27 times the. Volume - button and after the back menu function will turn on
95 Guest(s)
Devices in use: Desktop (80), Phone (15)
heftpflaster
rk.13
