Unbricking Arnova 7cG2 - Original ROM backup
This topic is locked
olavo
31
2012/02/07 - 12:12
tremendo said
great, i am trying this in a few minutes, thanks.
what's the usb vendor and prduct id for arnova 7cg2 in fastboot mode?
is it this?
 ID 18d1:d00d
Hi there,
My 7cg2 is also bricked. it gets stuck at the android logo.
Can you please help me to unbrick it?
All the links provided are down.
Thanks Received: 3171
32
2012/02/07 - 12:15
Flashing setialpha firmware using fastboot should help you to get back a working device
http://www.arctablet.com/blog/forum/arnova-7c-g2/nano-cfw-arnova7cg2/
olavo
33
2012/02/07 - 12:21
Hi, Admin,
Thank you for the extreamly fast reply.
But this is as cfw isn't it? Is it stable enough for the 7cg2 or should i be better sending my 7cg2 back to the factory?
Best regards 🙂Laugh
crusti
34
2012/02/11 - 00:53
Are there any other links to "msm7627_fw8918-ota-eng_0045_0817.zip", the megaupload link has a pic from the FBI the other link doesnt not exist according to my google.
I could find it mentioned on an Italian site via google but no download link.
I want to try the original rom again because I am trying out the CFW nano but I cant get a lock with GPS and the Market app crashes all the time but apart from those glitches its a very good CFW, just want to know if GPS still works on stock FW to see if the CFW has GPS problem.
Edit : Market is working great now.
Id like to try out DanielVD FW but im unsure how to use Tremendos method, looked through the threads but its not clear what it means.
DanielVd
Forum Posts: 237
Thanks Received: 5
35
2012/02/11 - 08:31
DanielVd said
How to flash my ROM:
  • Download my rom and put it into the sd
  • Download this recovery: http://www.mediafire.com/?dorpdubo5z1cqnk
  • Flash it by fastboot, fastboot flash recovery recovery.img
  • wait until it finishes
  • Reboot the tablet with fastboot continue
  • When the tablet will turn on give the command adb reboot recovery from your pc
  • you will have a recovery like this: Image Enlarger
  • Press 27 times the button volume - and will appear a string: BACK MENU BUTTON ENABLED
  • Now you can navigate ang choose install zip from sd card by clicking with search button
  • After choose zip from sdcard and choose my rom (everytime with search button for choosing)
  • after choose yes - install ....
  • Wait until it will finish
  • now go back and choose reboot system now and you will enter into the new rom
Thanks Received: 264
94 Guest(s)
Devices in use: Desktop (78), Phone (16)
heftpflaster
rk.13
