Unbricking Arnova 7cG2 - Original ROM backup
This topic is locked
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/13 - 16:02
Here the backup, can someone work on a recovery now?
http://www.megaupload.com/?d=S61QGQU6
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/13 - 16:35
Please admin & mod make a recovery ūüôā
finless
Stanton, Ca
Forum Posts: 604
2012/01/13 - 17:12
A recovery or a new modded ROM?
Npn
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/13 - 17:28
Npn
a recovery
finless
Stanton, Ca
Forum Posts: 604
2012/01/13 - 18:36
OK wait... you want a update.img you can unbrick the tablet from?
That link to megaupload, what is that?  Where did it come from?  The source has to be solid or the update.img wont work.
Finally the 7C is a different tablet than the others.  Different processor, etc and thus the rockchip tools I am using today do not work with this!  I do not have the knpowledge right now about the Qualcomm processor and flash tools.  Maybe if you can point me to the tool set  I can try to make a update.img or whatever this tablet uses to flash for recovery.
Bob
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/13 - 18:38
Bob
The megaupload file is an original 7cG2 rom, i found it on my sd when the tablet came back from Assistence center.
I tried with fastboot update file.zip but it tells thatthere is not some .txt files.
finless
Stanton, Ca
Forum Posts: 604
2012/01/13 - 18:41
So what are the tools used to flash this?  Can you point me to somewhere that explains how this tablet works and how it is flashed?
Bob
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/13 - 18:44
Bob
there is not a tool for flash this! the only way is with a custom recovery (using this guide http://www.koushikdutta.com/2010/10/porting-clockwork-recovery-to-new.html) but i can't because when i tried to download the files of the guide always there is some problem, if you can create a custom recovery (like clockworkmod) after i can flash with recovery
simondo
Forum Posts: 78
2012/01/13 - 18:54
You should be able to port lg p500's clockworkmod or even better the lg optimus slider which has same processor
finless
Stanton, Ca
Forum Posts: 604
2012/01/13 - 18:55
OK try this one.  NO GAURENTEE!
http://www.helifreakswasg.com/7cg2recovery.zip
Bob
benhum
2012/01/13 - 19:07
Woah - the original post *IS* a recovery file.  Download it, there's a zip inside the downloaded zip (msm7627_fw8918-ota-eng_0045_0817.zip).  Rename this to update.zip, and put it in the root of your microSD card.  Boot the Arnova into recovery mode, then restore from this zip file.
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/13 - 19:19
there is not a recovery mode on arnova!
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/13 - 19:24
Bob
i flash it, but now how can i enter into recovery?
simondo
Forum Posts: 78
2012/01/13 - 19:49
If your rooted then download rom manager and that has a reboot into recovery option
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/13 - 19:50
i tell you again! in arnova there is not a recovery graphic mode! and there is not a clockworkmod!
87 Guest(s)
Devices in use: Desktop (70), Phone (17)
heftpflaster
rk.13
