NEED HELP TO FLASH/UNBRICK/RESTORE YOUR DEVICE ? I`M HERE !
Related Tags This topic is locked
Thanks Received: 268
91
2012/11/11 - 17:35
the guides are here on the forum, i writen them several times
i do not perform anymore the team viewer unbriking.
chifleta
92
2012/11/11 - 18:24
Yes, but like I said, none of the guides have worked for my tablet - there was one that said do reset and plug in and press power and volume down button, but my tablet hasn't got a volume button (my volume is on the actual screen).  Thanks for the reply though, if you know anywhere else I can ask, would be much appreciated.
ps what is team viewer unbriking? and should I be glad LOL
Thanks Received: 3177
93
2012/11/11 - 18:39
No volume button, are you sure you have an Arnova 7c G2 ? If not please check in the right forum section.
chifleta
94
2012/11/11 - 18:45
I already said in my original enquiry (on page 5 or 6 of this thread) that I have an Aronova 7G2 .... and i've looked through heaps of threads on this site, but there seemed to be no answer to reset factory settings on the 7G2 that worked for me, but I was hoping that globula_neagra could help, as he seemed to give the most knowledgable advice where people had actually said "thanks mate, that worked" .... it looks like he can't help unfortunately, so hey ho :) thanks anyway - it was worth a try.
chifleta
95
2012/11/11 - 18:50
actually, if someone could post the link for the page that has the answer, because i've looked, and looked, but can't find it.
ps. so what is unbriking? as i'm still none the wiser!!
96
2012/11/11 - 18:56
A bricked device is one that doesn't boot and can't be used as a tablet anymore, it's just like a paperweight or a brick.
Well, it wasn't clear if you had a 7G2 or 7c G2 since you persists in writing in this 7c G2 forum which is a different device, while there is a specific forum for the 7 G2
chifleta
97
2012/11/11 - 19:05
ahhh right... bugger, that's what i've got now, a modern looking paperweight LOL
ok, I will copy and paste my original query in the correct area then, thanks for your patience ... fingers crossed for me Laugh all this technology does my head in.
sfktkr
98
2012/12/11 - 00:23
can i get help too ?  sfktkr@gmail.com  pls contact me
mckay99uk
Derby UK
99
2012/12/22 - 23:52
ray said
ray said
globula_neagra said
As the topic says, if you need help to flash your arnova, type your message here, and i will help you.
Users helped:
STC
pedrobelo
daktylus
Method used:
Using team viewer to acces your computer and instal the requiered programs and applications, and flashing the proper files to your device.
Use this topic please for any question regarding flashing, adb, fastboot, android sdk, java sdk.
If you think that you can do`it yourself, use the tutorials provided on the forum.
Conditions apply:
-I will do this in my free time
-I`m not asking money for it
Hi Globula-neagra,
 I'm new to this & not very good with computers either. I have been trying for the last few days to install the adb & fastboot drivers to my arnova 7c g2 (with 4GB sd).
 I think I followed the tutorial correctly, super one click appeared to work. However, when I try to check it I get wrong path or bad command messages from the cmd page on the computer.  I have tried with the sd card both in & out, & conecting the usb at different stages.
My arnova is recognised by the computer, but sometimes fails to start. I press the reset on the back, then it is ok. When I reboot the arnova I always choose the top menu option & have not wiped anything. I have not run the start up wizard.
I decided to continue with the nano upgrade & then got stuck when all the downloads (3) to the computer ask to be burnt to cd. I can't find a way to open them.
Any help/ideas would be gratefully received.
Ray
PS I have also been unable to install arc tools 5.7 & 6.3 & adobe, I tried to follow links from here.
My 7c G2 is also stuck on the flashing Android start up screen after i installed Arctools and downloaded the market apps. Can you help ?
100
2012/12/23 - 00:14
There are 2 ways, either you fallow the posted guides, either you check my signature.
I am not performing anymore free unbricking/flashing service, it is too time consuming.
will3032840hush
101
2012/12/30 - 15:29
How do I flash a UG802?
Please respond.
Also, tried manual flash adb and even all the flashers I could find, but nothing works...
102
2012/12/30 - 15:31
if you have adb working, you can put the device in downloading mode, then use rockchip tools to flash it.
will3032840hush
will3032840hush
103
2012/12/30 - 15:34
How do I put it in downloading mode? I tried saying su in terminal then reboot bootloader but that isn't working either
will3032840hush
104
2012/12/30 - 16:58
THANKS. I bricked my UG802....
how do I unbrick it if It refuses to go into downloading mode?
105
2012/12/30 - 17:11
do you get anny reaction when you connect it to the pc, any thing like install the drivers, new devices that up in device manager ?
52 Guest(s)
Devices in use: Desktop (49), Phone (3)
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
hamishduke
