NEED HELP TO FLASH/UNBRICK/RESTORE YOUR DEVICE ? I`M HERE !
Related Tags This topic is locked
peili
Germany
61
2012/08/15 - 18:43
So
fastboot devices
Arvova-2F.......A1 fastboot
fastboot flash boot boot.img
error cannot load 'boot.img'   (it´s the nano-boot.img)
and the same to trenano-recovery.img and nano-sysem.img
adb and super-one-click dosn´t work so i have the firmware downloaded, but it´s also no possible to load
i have all files in the same folder 'platform-tools' and the way in the devices manager is added C:\sdrandroid\platform-tools
that i min it´s correct, or not???
62
2012/08/15 - 18:55
As the error says, the image files cannot be loaded / found. Make sure you have downloaded the different image files (boot, system and recovery) to the directory where you are running fastboot command, also make sure the file names are the same you are sending to fastboot.
Thanks Received: 264
63
2012/08/15 - 19:10
Use drag and drop to get the exact path and file name
here a video on how to do it
http://youtu.be/gW1jh9VPRqk
peili
Germany
64
2012/08/15 - 20:12
SurprisedOHHHH MY GOOOD!!!!! Iám so stupid, idiot.........Surprised
You are all the greatest  (Copy and paste some works) what a wonderful emotions- my devices lifes!!!!! amazing
but tell me please, why dosn´t found the files when i type it?
and the last can i tray Rom Manager or something another root tools to optimize or is this not important?
again very very Thank's  for you     I'm soooooo happy!!!KissEmbarassedCool
65
2012/08/15 - 21:41
you can try root tools
rom manager is not designed for this tablet
the files where not found because i think you did not installed in the right way android sdk.
Peter Griffin
66
2012/08/23 - 17:34
hey
i think i could neeed some hep :/
i wanted to flash my arnova 9 g3 but now it doesn't work anymore ...
if i want to flash it with the rock chip flash tool it says 'Download IDB Fail'
i can't start it anymore
and everytime i connect it to my pc, my pc recognizes it and the tool also detects it ...
67
2012/08/23 - 22:15
this is the section for arnova 7c g2
kongitto
68
2012/08/30 - 14:27
Dear people,
Sorry if I'm not writting in the correct thread. Instead of starting one I'll try to solve my problems here.
After reading and trying to follow the instructions found 'on the net' the only result that I already have, is that I've totally have in an unrecoverable state on 7cG2. I think that I'va used the correct .img to flash it.
And that's the topic. Where can I found a reliable rooted .img for the 7cG2. I need to test some app in order to test drawing procedures just to avoid some memory leak situations.
I've tried to download from megaupload(oviously down),...
I was able to sync arnova 7cG2, adb was running and fastboot also. I followed Setialpha firmware instructions but I couldn't finish the procces, I got 'data too large' msg error for the image that I used.
I've purchased another 7cG2 and prior to make the same mistakes,... that's why I'd like to test with a reliable .img.
Anyone can help putting me in the rigth path?Wink
Any idea? Any help?
Thanks in advance
69
2012/08/30 - 14:42
I think we can recover the other tablet.
First from this tablet that you have now, get it on fastboot from adb
download from here
http://downloads.nanolx.org/index.php?dir=7CG2_NanoCFW_rev14%2F
nano-system.img
nano-boot-nosd.img
trenano-recovery-nosd.img
adb reboot bootloader
fastboot devices (to check if it is fastboot)
fastboot erase boot
fastboot flash boot nano-boot-nosd.img
fastboot erase system
fastboot flash system nano-system.img
fastboot erase recovery
fastboot flash recovery trenano-recovery-nosd.img
Use drag and drop to get the exact path of the files, you can use the video for example
to get the other tablet in fastboot mode (the one that is bricked)
press the rest button from the back of the tablet
connect the tablet to the pc, wait till you see a continious light, or a flashing light on the buttons
press in the same time the power and the volume key that lowers the button, you should hear a sound from your pc if you do it corectly
check if the tablet is in fastboot with fasboot devices, it if is do this :
fastboot erase boot
70
2012/08/30 - 14:44
if you get the same error with the data to large, i will try to upload a older version that is smaller but some time will pass, i am using a 3g connection.
peili
Germany
71
2012/08/30 - 14:55
hey,
please don't forgot at the last
fastboot continue
to restart the tablet.
it war's my mistake of my mind i heaved brick my devices.Surprised
kongitto
72
2012/08/30 - 15:29
Many Many thanks to globula_neagraWink.
He put me in the correct way.
For some other the work to do:
URL: http://www.arctablet.com/blog/forum/arnova-7c-g2-android-firmware-development/need-help-to-flash-im-here-1/page-5/#p12428
Thanks peopleLaugh
73
2012/08/30 - 18:06
i forgot about fastboot continue :D
i am to used with the commands and i asume that everybody knows that command :D
liamalucien
74
2012/11/09 - 03:44
Hey man!
I have been on this forum for two days now as well as XDA and androidforums but, I can't seem to find the answers I need.
I have an Arnova 7c G2 which is currently stuck on the 'ARNOVA' booting screen.
I have installed Java RTE, Android SDK, I have setup up my C:\Android path in the command line for 'path', and have downloaded Superonclick and 'Recovey.img, system.img and nanoboot.img and trenano-boot.img etc and I cannot get anything to fix this tablet.
1. I cannot connect to ADB. Superoneclick does not tell me to install the drivers when I click check drivers... nothing happens.
So i cannot install the ADB Android drivers (Is there another way?)
2. I Cannot put the device in 'USB Debugging mode' as I cannot even start the tablet into android. (I bought it second hand like this).
3. When I try to flash the recovery.img file i get an error message saying, 'error cannot load recovery.img' and it says that for any file I try to flash.
4.The device doe show up in CMD when i type 'fastboot devices'. It shows Arnova then the long number etc.
I have been trying this for two days and done so much scouring of the web and trying stuff to no avail. I believe it is time for this post.
Please can somebody help me out, many thanks in advance
Liam ;)
75
2012/11/09 - 09:12
Since the device goes in fastboot, per your point 4. on are on the right track. The problem is probably the path of your image that need to be in the directory you run the adb commands from. See globula post #63 to properly drop the images there. Our 7c G2 flashing tutorial video may help as well.
PS: I have removed your double post, I don't think it was necessary.
76 Guest(s)
Devices in use: Desktop (69), Phone (7)
cutierogue
hans41
rickybk
