NEED HELP TO FLASH/UNBRICK/RESTORE YOUR DEVICE ? I`M HERE !
Related Tags This topic is locked
jake
31
2012/06/19 - 15:02
Thank you, so if I am following correctly those tutorials will then allow me to install the Google Play store onto my device?
Thanks Received: 268
32
2012/06/19 - 15:39
you will be able to flash a custom rom, that has google play.
jake
33
2012/06/19 - 15:44
Thank you, I am completely new to all of this so I am in way way over my head here! Thank you for your help, I will take a look through the tutorials and try to make some sense out of them,
Thanks!
34
2012/06/19 - 15:48
If you fail somewhere, just re-read the tutorial.
neca
35
2012/06/25 - 14:32
I'm having problems with flashing arnova 7c g2. Can you help me?
Thanks in advance.
36
2012/06/25 - 14:35
Thanks in advance.
Have you read to tutorials and links given by globula_neagra, which kind of problems are you having ?
neca
37
2012/06/25 - 15:00
I red them few times and i have a problem with installing drivers for arnova 7c g2. I put tablet in debug mode, download drivers as you described, and drivers won't install.
i tried few times, restarting computer, changnig usb ports...and it won't pass.
38
2012/06/25 - 17:19
try to boot the tablet in normal mode
enable usb debugging from settings/aplications/development
then download superoneclick from here http://www.arctablet.com/blog/forum/arnova-7c-g2-android-firmware-development/useful-stuff/
Try to install the drivers with the stock superoneclick
If it does not work, copy the arnova drivers, in the folder named drivers from the superoneclick (ofcourse, unrar the file)
If it does not work like this, it means that you have windows xp, or vista which raises mode problems when you whant yo install the drivers.
If you manage to install them, then get the tablet in fasboot mode, and see also if the bootloader interface is installed, if not, install it with superoneclick
There is also another app that installd the drivers, it is called Unlock Root, you can google this if superoneclick does not work also.
Tho check if the drivers are installed use the fallowing
adb devices
fastboot devices
rusyasmile
39
2012/06/25 - 22:56
I CAN NOT TO MOVE MY ARNOVA DEVICE IN FASTBOOT MODE. I TRIED TO PRESS BOTH BUTTONS POWER AND VOLUME- LONG TIME WITH NO RESULT. CAN YOU HELP ME?
40
2012/06/26 - 00:35
shut down the device, connect the table to the computer, you will see the keys flashing
press IN THE SAME TIME THE POWER BUTTON AND VOLUME KEY MINUS
You should hear a sound from your computer if you do it right.
You can use the reset button from the back of the tablet to shut it down faster
rusyasmile
41
2012/06/26 - 15:20
nothing happened. I faced with one misunderstanding. when I connect the tablet in normal mode to my PC the PC gives a message "found new hardware Arnova 7c g2" and new hardware installation wizard window appears. I click on tab "Cancel". it happens four times. after that I can work in SuperOneClick and my device is recognised in command promt:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Руся>cd "C:\Program Files\Android\android-sdk\platform -tools\"
C:\Program Files\Android\android-sdk\platform-tools>adb devices
List of devices attached
0123456789ABCDEF device
when I try to connect the tablet to the PC in fastboot mode (I make it as you wrote me. thank a lot for this) the same message
42
2012/06/26 - 15:24
if you get the result from above it means that the adb is working, same for fastboot
you can get in fastboot mode also from adb
adb reboot bootloader
sammonsmx
Forum Posts: 36
43
2012/07/06 - 01:12
Hi, I have an unusual scenario.  Similar to rusyasmile I can't get to fastboot.  I can get ADB devices showing the device, and then use adb reboot bootloader.  The device shutsdown and does not reboot.  Power button and down vol does not work, i.e. no flashing lights and no USB sound. Superoneclick does not see the device.  Off of the USB cable the device starts and boots normally into stock ROM.  USB debugging is on.  I reinstalled stock rom from links on this site.  Still unable to get to fastboot.  Maybe I'll just have to stick with the stock ROM!
44
2012/07/06 - 01:42
rusyansmile managed to get the arnova in fastboot mode 🙂
i think your fastboot mode is somehow broken/deleted
sammonsmx
Forum Posts: 36
45
2012/07/06 - 09:31
I agree - I'll try to get the best out of the stock ROM.
150 Guest(s)
Devices in use: Desktop (140), Phone (10)
