As the topic says, if you need help to flash your arnova, type your message here, and i will help you.
Users helped:
cadeteseamus22
chulis
enas123
daktylus
frachma
jmrgariel
magicdj
STC
sammonsmx
pedrobelo
paulomhalmeida
ray
Vasanth
ukoeni
olavo
paulr
myself
100 percent succes rate till now
Method used:
Using team viewer to acces your computer and instal the requiered programs and applications, and flashing the proper files to your device.
Use this topic please for any question regarding flashing, adb, fastboot, android sdk, java sdk.
If you think that you can do`it yourself, use the tutorials provided on the forum.
Conditions apply:
-I will do this in my free time
This project is stopped, i can not perform anymore work for free as it takes time and time means money.
Check mi signature for other detailes.
kbramH
2012/03/27
globula_neagra said
As the topic says, if you need help to flash your arnova, type your message here, and i will help you.Users helped:
STC
pedrobelo
daktylus
Method used:
Conditions apply:
-I`m not asking money for it
Hi Globula-neagra,
 I'm new to this & not very good with computers either. I have been trying for the last few days to install the adb & fastboot drivers to my arnova 7c g2 (with 4GB sd).
 I think I followed the tutorial correctly, super one click appeared to work. However, when I try to check it I get wrong path or bad command messages from the cmd page on the computer. I have tried with the sd card both in & out, & conecting the usb at different stages.
My arnova is recognised by the computer, but sometimes fails to start. I press the reset on the back, then it is ok. When I reboot the arnova I always choose the top menu option & have not wiped anything. I have not run the start up wizard.
I decided to continue with the nano upgrade & then got stuck when all the downloads (3) to the computer ask to be burnt to cd. I can't find a way to open them.
Any help/ideas would be gratefully received.
Ray
2012/03/27
ray said
STC
pedrobelo
daktylus
Method used:
Conditions apply:
Hi Globula-neagra,
Ray
PS I have also been unable to install arc tools 5.7 & 6.3 & adobe, I tried to follow links from here.
tomorrow after 5pm uk time i will be on.
kbramH
please instal team viewer and send me the id and password via private message
yes, you need team viewer instaled and send me via pm the id and password for login
2012/03/27
Hi Globula_neagra
I'm stuck again, nano upgrade was working well, except I ended up with lots of different versions of adobe, all of which would install but will not run including 4shared and mediafire. Same with bbc Iplayer although the Iplayer will run but, won't play programs I presume a flash player is needed to make it work properly.
I deleted a load of old an unused files to clean up and make space. Unfortunately I think I have deleted too much, now Talk will not open, maps repeatedly force closes and google play gives server error, retry. I can get into play through the browse my account at Google is active But they say I must sign in to talk to download, I have reinstalled Play from different website but this has not solved the problem Everything else appears to be working well. I have not made any backups, I have rebooted and also reset the pin on the back. I have not tried a factory reset. I do not think this is a google problem, I think I have deleted a file or a setting somewhere.
Any ideas please,
Thanks ray
you need to do a factory reset if you want a functional system again 🙂
you have were some apps and some application that can make your experience better with arnova 7cg2
http://www.arctablet.com/blog/forum/arnova-7c-g2-android-firmware-development/useful-stuff/
56 Guest(s)
Devices in use: Desktop (49), Phone (7)
hans41
rickybk
soniya07
ironmangitar
