Nano CFW rev14 [2012.08.16] Android Market and DC2SD
asnyper
Forum Posts: 17
61
2012/01/29 - 01:13
Admin said :  Both files (nano-boot.img and stock-system.img) should go in the same directory as flashboot
I put (nano-boot.img and stock-system.img) in C/ANDROID6SDK/ tools .... with fastboot.exe ..... what do you meen by "flashboot" ??
I tried the same cmd and I have the same message error :
c:tools>fastboot erase flash
erasing'flash' … FAILED <remote: unknow partition name>
can anyone help me ?
tremendo
Forum Posts: 42
62
2012/01/29 - 02:54
I did the whole procedure and now i have a market installed and working -- great! however i downloaded root checker and it says the device is not fully rooted. how can i access busybox? starting the terminal emulator gives me the usual shell (no ls -al for example).
Id like to be able to su and edit /etc/hosts while on the go, what am i supposed to do?
ra2000
Forum Posts: 32
63
2012/01/29 - 09:47
Just a thought, but did you see the revised instruction by Jameslewisuk on Post #60 ?
"fastboot erase flash"      SORRY THIS SHOULD BE "fastboot erase system"
I can't help on the "flashboot" as I'm a learner here.
jameslewisuk
Forum Posts: 79
64
2012/01/29 - 11:51
Use super one click root
http://www.mediafire.com/?ghyh3p0rw9txq4p
salvaggente
65
2012/01/29 - 12:42
salvaggente said
Hello, I am also the owner of 7cG2!
Thank you for the work you do for us ..
- I wanted to know if it was possible to implement the USB, to connect peripherals such as mouse, pen-drive, etc. .. (or if there is any other way);
- The latest verision flasplayer is integrated? you can install it manually?
I agree to CFW without programs, without compromising the various copyright .. so each user can customize at will. Laugh
I can give no answer?
Italy - Arnova 7cG2
asnyper
Forum Posts: 17
66
2012/01/29 - 14:01
Hello everyone,
I try to install this ROM for 2 days without success.
this is what I did:
==> I install the SDK on my PC windows7 64bit
==> I put both files (nano-boot.img and stock system.img) in the folder (C / android-sdk / tools)
==> I launched the CMD:
1 - c: tools> fastboot devices
          ARNOVA-53f4d5zz12536666 fastboot
2 - c: tools> fatsboot erase boot
          erasing'boot '... .. OKAY
3 - c: tools> fastboot erase system
           erasing'system '... .. OKAY
4 - c: tools> fastboot flash boot nano-boot.img
          error: can not load 'nano-boot.img' .... !!!!!!
someone could tell me what to do ? I have to install a FlashBoot ? (I don't know what is it)
my tablet will not boot !!!!!
thank you for your answers
jameslewisuk
Forum Posts: 79
67
2012/01/29 - 14:21
asnyper said
Hello everyone,
this is what I did:
4 - c: tools> fastboot flash boot boot.img nano-
someone could tell me what to do?
You haven't got nano-boot.img or stock-system.img files in the directory (folder) you are trying to run fastboot from.  You're nearly there.  Just put  nano-boot.img and stock-system.img files in your c:/tools and try again
then type these commands, again without quotes
"fastboot erase boot"
"fastboot flash boot nano-boot.img"
"fastboot flash system stock-system.img"
"fastboot -w"   (reset to factory settings)
"fastboot reboot"
DanielVd
Forum Posts: 237
Thanks Received: 5
68
2012/01/29 - 14:55
asnyper said
Hello everyone,
this is what I did:
Copy on c:\nano-boot.img and try fastboot flash boot C:\nano-boot.img
asnyper
Forum Posts: 17
69
2012/01/29 - 15:01
asnyper said
Hello everyone,
this is what I did:
Edit : I found the solution : I had a wrong way (C:android-sdk>tools)
===> My tablette works fine  Laugh
ra2000
Forum Posts: 32
70
2012/01/29 - 15:31
Congrats asynper - I'm still waiting for my 3G sim to arrive before I can do the same ..... patience, patience ......... mustn't yell at the kids, stay calm ..... it will arrive soon.......
Many thanks to setialpha for all your hard work & knowledge sharing and to the experienced helpers on this forum in helping us rookies - it's really appreciated 🙂
........ now come on Mr Postman !
tremendo
Forum Posts: 42
71
2012/01/29 - 15:46
jameslewisuk: never been able to get SOC to work, tried vista and xp.. i need a linux method i think
DanielVd
Forum Posts: 237
Thanks Received: 5
72
2012/01/29 - 16:01
There is linux version: http://forum.xda-developers.com/showpost.php?p=8699742&postcount=537
asnyper
Forum Posts: 17
73
2012/01/29 - 16:38
I did not understand this part :
DON'T reboot device at this point! Connect tablet to PC, open terminal and go to the directory that contains adb. Then issue the following commands !!!!!
someone can detail what to do (on the PC or tablet) and especially how?
Thank you for your answers (I'm really new to computers)
jameslewisuk
Forum Posts: 79
74
2012/01/29 - 17:05
This is the one that worked for me, make sure you install ADB driver, there is another advanced tab on the program that willl force install a driver if you need to try that
jameslewisuk
Forum Posts: 79
75
2012/01/29 - 17:15
 Have a look at video in post 47 of this thread
http://www.arctablet.com/blog/forum/arnova-7c-g2/nano-cfw-arnova7cg2/page-2/#p3902
109 Guest(s)
2 Guest(s)
Devices in use: Desktop (98), Phone (10), Tablet (1)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
