2012/01/28
thank you for your answer jameslewisuk
I tried to follow your tutorial but I think I'm missing components (SDK, fastboot,....) or I do not put them in the right place.
When I run the command lines it nothing happens.
I would need a more detailed tutorial from AZ : programs to download, install or how and in what order, ....
if someone could make a topic just for this, it would be very nice.
I searched the internet without successÂ
2012/01/20
I would need a more detailed tutorial from AZ : programs to download, install or how and in what order, ....if someone could make a topic just for this, it would be very nice.
To install fastboot (and adb) have a look at this video
2012/01/16
I need to know a little detail please
you say "
Start device as normal, install arctools 0.61 – run arctools and choose *second* option (default apps + market 3.4.4) – download and install. DON'T reboot device at this point!
adb pull /system/app/StartupWizard.apk
adb pull /system/app/Wizard.apk
adb shell
rm /system/app/*Wizard*
rm /data/data/com.android.providers.settings/databases/*
mkdir /mnt/sdcard/cache
exit
adb push SetupWizard.apk /system/app/"
question is? once arctools download and installed default apps etc, dont reboot?
how do you do the adb bits as as a newbie to this stuff I thought you had to shut down and reboot fastboot to do the adb stuff or is shuting down and starting fastboot not the same as reboot???????????
2012/01/16
2012/01/16
2012/01/16
From first view I'd say this is just for translation. Will compile for you either way.
Edit: framework-res.apk http://www.nanolx.org/downloads/framework-res.apk
2012/01/26
Congratulations Setialpha, I can't wait to try this and to Jameslewisuk for the video as I am completely new to this area of ADB, SDK etc so this will be invaluable.
Just a quick question Setialpha, at the start you say, "we need 3G as kickstarter ...."Â
Please excuse the dumb question - I am waiting for a Vectone SIM card to arrive for this tablet; so does this mean I won't be able to do this ROM update until I have a 3g SIM card because the download & install of the >2 MB app must be done by 3g and NOT Wifi ?Â
Thanks, once again for all the great work !
2012/01/16
2012/01/28
can someone help me please :Â
in which folder I have to put  nano-boot.img and stock-system.img ?
I put them in this folder : C:android-sdktools  .... is it the good place ?
I have this message :
c:tools>fastboot erase flash
erasing'flash' ... FAILED <remote: unknow partition name>
c:tools>fastboot flash boot nano-boot.img
error : cannot load 'nano-boot.img'
and now my tablette doesn't restartÂ
c:tools>fastboot devicesArnova-53f4d5zz12536666 fastbootÂc:tools>fatsboot erase booterasing'boot' ..... OKAYÂc:tools>fastboot erase flash
Both files (nano-boot.img and stock-system.img) should go in the same directory as flashboot
2012/01/20
jameslewisuk said
then type these commands, again without quotes
"fastboot erase boot"
"fastboot erase flash" Â Â Â SORRY THIS SHOULD BE "fastboot erase system"
"fastboot flash boot nano-boot.img"
"fastboot flash system stock-system.img"
"fastboot -w" Â Optional to reset to factory settings
"fastboot reboot"
Then your device should boot up in to the new firmware.
82 Guest(s)
2 Guest(s)
Devices in use: Desktop (72), Phone (10)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
