2013/02/18
I aprecciate your help, but I can´t mount, with this module cifs.ko, it´s said " no such device" in directories /mnt/cifs or /mnt/sdcard/cifsÂ
I read it´s necesary would be compatible or compile one exclusive for this kernell 2.6.35.7-perf+bingo@foxda-desktop #2
Âż anybody have got mounting sd card in external device ? has anybody using the app "mount manager" or "cifs manager"?Â
You run GB?
2014/09/11
Downloads:
http://downloads.nanolx.org/index.php?dir=7CG2_NanoCFW_rev14
Download nano-system.img and the proper nano-boot/trenano-recovery.img (checksums included)
help me please... dont find the download "nano-system.img, trenano-recovery.img"
need it
greetings roflkopter
I still might have them somewhere. I will have a look
2015/01/13
setialpha said
I'm pleased to announce the immediate availability of release 14 of my custom firmware :]Â
My ROM features:
- modifed UI
- fancy bootanimation
- busybox
- /data and /cache on SD-Card (optional)
- Google Play Market
- ES FileManager
- full root access
- better GPS settings
- more pre-defined APN/SPN
- higher responsiveness/smoothness
- ClockWork-Mod based recovery [thanks to Tremendo]
If you want to create your own ROM, there's also a Toolbox:
http://www.arctablet.com/blog/forum/arnova-7c-g2/everything-to-make-your-own-rom-gnulinux-1/
Changes since 13b:
nano-boot rev40:
removed some tweaks that are in 20netspeed
changed some 3G/EDGE settings
fixed a bug in 3G/EDGE settings
change WiFi scan interval from 300 to 180
change max WM events from 280 to 60Â
nano-system rev110:
UPDATE: zoneinfo to 2012c
UPDATE: OpenGL libraries
UPDATE: Play Store to 3.5.19
UPDATE ES Explorer to 1.6.1.6NEW: tun.ko (loaded at startup)
BUGFIX: make modprobe work
Init-Script changes:
10memory:
- previously: 10ministrictfree
- more memory tweaks20netspeed:
- some more minor tweaks40block:
- also apply for MMC
- many more performance tweaks50defragdb:
- can now be disabled via
echo 0 > /system/etc/defragdb
on a shell on the device.NEW 70kernel:
- misc kernel settingsNEW 80firewall:
- several firewalling settings
(for example PING/IMCP protection)NEW 95zipalgin:
- zipalign stuff from /data/app/REMOVED 99misc
All initscripts can be en/disabled via /system/etc/initcontrol
APN/SPN Settings:
If you encounter problems with APN/SPN settings
you may switch to the old (pre rev13) configuration:
apnswitch old
inside a shell on the device, respectively:
apnswitch new
to go back to the new configurationCPU settings editor:
- added (run: cpu)
- default settings:
+ minimal frequency: 600 MHz
+ governor: performance
+ sticky mode: enabledÂ
trenano-recovery.img rev03:
What is DC2SD?
DC2SD stands for Data&Cache To SD-Card. It takes two partitions of the SD-Card and uses them for /data and /cache - rather than the two internal partitions. If you prefer using the internal partitions, use the "NoSD" version, else choose between EXT4 and EXT2 versions of DC2SD.
If you flash the DC2SD version you must partition your SD-Card, else everything that needs /cache will fail and /data will be limited to ~2 Mb!
So if you got no clue what this is all about, choose the NoSD version!
Downloads:
MTD/ contains some stuff usefull for developers
GPS/ contains gps settings for various regions (replace /system/etc/gps.conf on device)
Other/ contains misc. stuff (adobe flash, older scripts, ADB drivers for Windows)
Installation:
Step 0: n00b step to avoid copy-paste commands not working
rename the downloaded NanoBoot to: nano-boot.img
rename the downlaoded TreNanoRecovery to: trenano-recovery.img
Step 1: partitioning SD-Card [ONLY for DC2SD]
 You need to create 3 partitions on your SD-Card:
- partition 1: used as usual external sd-storage, use FAT32 as file-system, choose size wisely yourself*
- partition 2: used as /data, use EXT4/EXT2** as file-system, choose size wisely yourself*
- partition 3: used as /cache, use EXT4/EXT2** as file-system, atleast 250 MB*
All partitions MUST be primary partitions!
* Example with 8gb SD-Card: 3,85 GB partition 1, 3,85 GB partition 2, remaining space partition 3.
** ... EXT4 is recommended (more secure and reliable, journaling FS), EXT2 is faster
** ... if you got a class 8 SD-Card you should use EXT4, on slower cards EXT2 might be
** ... the less annoying choice -> flash the correct images according to filesystem!!
Step 2: Flashing trenano-recovery.img:
Put phone into fastboot mode (shutdown and start by pressing power+lower-volume):
fastboot flash recovery trenano-recovery.img
Step 3: Flashing nano-boot.img and nano-system.img:
fastboot flash boot nano-boot.img
fastboot -w erase system [if flashing without won't give proper booting system]
fastboot flash system nano-system.img
fastboot continue
NOTE 001:
you should use atleast a class 6 SD-Card for DC2SD, class 8 recommended. The 7cG2 supports Class 10 SD-Cards aswell.
 NOTE 002:
after flash it might take up to 2 - 3 minutes for your device to be fully initialized for the FIRST start - have no fear if it does not seem to do anything - just relax and wait. (you can see what it does using 'adb logcat' - if you doubt it does anything)
NOTE 003:
when using DC2SD use internal storage, when installing applications NOT sdcard - obviously internal storage is partition 2 on the SD-Card then!
Advantages of /data and /cache on SD-Card:
- more space
- much easier backup (just put SD in PC and copy away)
- accidently wiping userdata won't have effect
- it's pure awesome
Disadvantages of /data and /cache on SD-Card:
- startup takes longer (depends on amount of apps installed)
- running an app the first time takes a bit longer (also depends on SD-Card speed)
 That's it!
GETTING OFFICIAL ANDROID MARKET TO WORK
Go to Settings > Accounts & Sync
- enable both options for backgrounddata
- add account
- open market and accept TOS
That's all - enjoy your Android Market on 7cG2.
HINT 001:
If you have a lot of images on the SD-Card, gallery3d is awwwfully slow in creating it's caches. I'd recommend "Just Pictures" from the market. Not as fancy, but much faster and also displays many images in better quality when double-tap for full-size.
HINT 002:
For those without credit-card, you might check the apps-center from http://www.androidpit.de - you pre-pay using paypal and then you can simply buy an app. Though they don't have all apps available, but a special offer each week.
Suggestions/Comments/Thanks welcome
Have Fun!
link is dead.... anyone have a working link???
75 Guest(s)
Devices in use: Desktop (67), Phone (8)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
