Nano CFW rev14 [2012.08.16] Android Market and DC2SD
Thanks Received: 268
541
2012/12/18 - 11:55
Yes, is worthing installing the custom firmware
There are multiple improvements on the 3d/2d side, the tablet is more fluid, you will gain more controll of the tablet by flashing a custom rom.
Da, sunt roman.
perrari
542
2012/12/18 - 12:46
Any GPS regarding Romania zone, after custom firmware? I heard someone talking about those errors with custom ROMs.
Multumesc.
543
2012/12/18 - 13:05
The gps can be improved by using a gps settings dedicated for Romania.
pedrosol
perrari
544
2012/12/18 - 15:13
Where I can find those settings, please?
545
2012/12/18 - 18:11
There are on xda some, search for them :) .
mleuko
546
2013/03/06 - 20:45
Ext4 and Ext2 boot images do not work any more since the server was down some days ago.
The booting hangs on the Arnova logo with those boot images. It worked before and it still works with nosd boot image.
547
2013/03/06 - 20:56
I don`t know why, i will check to see if we have some back`ups on the server
mleuko
etana
548
2013/03/24 - 19:48
Hi there
I just managed to install the nano no-sd rom on my Arnova 7c G2. Everything seems to work fine, except the most important thing: Google Play.
First I just tried to create an account from the settings, but it only offers me an exchange account.
So I tried to install "Default Apps & Market 3.4.4 (Android 2.3) "using Arctools 0.78. It said it did it and the log messages seem to indicate that it put the files into /system/app. So I did a reboot, but still
- there is no market in the app list
- cannot create a google play account
Any idea, what could be wrong? I understood that other users managed to get the market installed using the same procedure.
549
2013/03/24 - 20:46
you need to enable background data and it will work
it was specified anyway in the first post
Go to Settings > Accounts & Sync
enable both options for backgrounddata
add account
open market and accept TOS
mleuko
550
2013/03/25 - 11:59
Hi!
1)
Ext4 and Ext2 versions still do not boot on my tablet. Are the images corrupted?
Some weeks ago it was possible to boot these versions. I don't know why.
But I would like to use DC2SD!
2)
Are there any news regarding network location services?
Regards
etana
551
2013/03/25 - 17:47
@globula_neagra: unfortunately the enable background data flag is not the solution to my problem. I had it enabled all the time, but still see no market nor can create a google play account from the settings.
I checked the /system/app folder and found, that arctools appearantly copied the google files there. But the files were appearantly not installed to the system. I checke the file permissions and found, that the execute flag was set, different to the other files in the folder. I removed the flags and rebooted but unfortunately the solution was not so easy: still no market. I also tried to install them manually from my ez file explorer, but this seems not to work. Any ideas, what I could try next?
552
2013/03/25 - 18:05
You should re-install the firmware because i think you somehow screwed the permissions on the files when you used arctools
Arctools is not intended to be used on the 7cg2
After you re-install, enable first the background data then use market.
etana
etana
553
2013/03/27 - 23:41
Finanally got it working including market after deleting the 1st image and full reinstall. Indeed it works directly by creating google account from the settings without using arctools. Thank You all for this cool software and all the usefull hints!
etana
554
2013/03/27 - 23:45
Here ist the next question: I have downloaded Skype from google play. But unfortunately it is not using the front camera, indeed does not come with any video functionality at all. Is there any way to get this working with nano? would be more than usefull, the more as the Arnova 7c G3 is a tablet with a front camera only.
555
2013/03/28 - 00:05
try to use yahoo messenger, skype does not work on 7cg2
66 Guest(s)
2 Guest(s)
Devices in use: Desktop (64), Phone (2)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
