Nano CFW rev14 [2012.08.16] Android Market and DC2SD
chrisspider21
526
2012/12/09 - 15:34
globula_neagra said
drag an drop the files in CMD to get the exact path of the files
Is your tablet booting normally ?
If it is, did you enabled usb debugging ?
If you did enabled the usb debugging, did you installed the drivers ?
If you did installed the drivers, did you verified if adb is working, by using the command "adb devices" ?
NOPE TABLET not booting now.....   yes enabled usb debugging....  drivers installed auto when started up with power and down volume the computer then installed it... adb works but nothing now comes up when 'adb devices'
So with this info what can i do? Have i bricked it??  it does get recognised by the computer but doesnt display? Again your help has been invaluable......    I think i was almost there but if your free can you resolve it??
Thanks Received: 268
527
2012/12/09 - 15:44
but when you type adb devices, in which state is you device ?
Are you in fastboot mode or in normal boot mode ?
chrisspider21
528
2012/12/09 - 15:47
When is type adb devices it say List of devices attached
Now in fastboot mode but it is seen as android phone in device manager
529
2012/12/09 - 16:08
when you are in fastboot mode (that means after you shut down the tablet and press in the same time the power and the volume button) the adb WILL NOT WORK
you can use only fastboot commands.
To make it clear, adb will not work if the tablet is not booted (that means that you need to see a image on your tablet, and also you need debugging activated)
When you are in fastboot mode, which is a state where you need to get the tablet by shutting down the tablet and then press the power and volume key, you can only use commands that start with "fastboot xxxxx"
If you did not installed the drivers fastboot/adb will not work.
If you want that i flash your tablet and learn you how to do it on the future, make me a donation, and will help you via a remote connection.
chrisspider21
530
2012/12/09 - 16:25
I give up....  ive sent you a PM!
ahmedegypt
531
2012/12/13 - 15:17
Hi, any one knows if the new room of firmware from "setialpha" support arabic language or no ?
second issue, does the link to download the room which is located in the first page topic 1 is the one with last modified ...  thanks too much
532
2012/12/13 - 15:48
Version 14 is the last firmware.
I don`t have knowldge about the arabic/asian support, you will have to try :) .
ahmedegypt
ahmedegypt
533
2012/12/13 - 17:09
i ahve another question ... , for the useful files which mentioned in the download link or in other page about useful for Arnova,
after i download all, how can i install them on my Tablet
534
2012/12/13 - 18:59
On which files are you refearing ?
ahmedegypt
535
2012/12/13 - 19:16
programs like flash playeer or gps .. in that link
http://downloads.nanolx.org/index.php?dir=7CG2_NanoCFW_rev14
i checked my new Arnova 7c g2 now, and it is not supporting arabic ?
i will frimware it now with the new room , but if it still not supporting arabic , can i bring it back to the original system cause i will return it again to the market ..
536
2012/12/13 - 19:49
Tell me what firmware version you have now
ahmedegypt
537
2012/12/13 - 19:59
i have 2.3.3
but i started to frimware it, i did all the steps, and waiting to reboot but is 10 minutes without rebooting
just the ARNOVA  sign  ??
ivan.s
538
2012/12/16 - 12:21
Hello everybody Smile
I can't find Set up screen lock in Settings > Location &
security
. Is it posible to set up a PIN for lock screen in this firmware (Nano CFW rev 84)?
539
2012/12/16 - 12:35
From what i remeber, no.
You could use some apps from the market tough.
perrari
540
2012/12/18 - 08:42
Hi there.
I have this 7CG2 tablet and my question is if it's worth install this custom ROM only for the Google Play, becouse lack of this is the only thing that I miss on the stock ROM.
May this operation affect the warranty of the product?
PS: globula_neagra, esti roman? :)
Currently Online: WhiteD2125
64 Guest(s)
2 Guest(s)
Devices in use: Desktop (62), Phone (3)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
