Nano CFW rev14 [2012.08.16] Android Market and DC2SD
destructa
Forum Posts: 17
496
2012/06/22 - 16:31
globula_neagra said
No, that file was other purposes, don`t copy it to the tablet
OK.
You said that you'd do a patch, any update on that?  (I know you're busy!)
FYI I am in the UK.
D.
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
497
2012/06/30 - 18:01
So... the BETA is now online.
ONLY USE THIS IF YOU KNOW WHAT **BETA** MEANS!!
Download: http://downloads.nanolx.org/index.php?dir=7CG2_BETA%2F
ChangeLog: http://downloads.nanolx.org/7CG2_BETA/CHANGES_14
gps_settings.tar.bz2 contains different gps.conf for all continents, SHA1 checksums provided aswell.
Thanks Received: 268
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
499
2012/06/30 - 22:18
There's a newer version? Hmm... no auto-update here. I'll check that new version soon. Thanks.
BTW: It seems my WLAN (aka WiFi) speed is noticeable faster than with rev13 - anybody can reproduce this?
500
2012/06/30 - 22:51
i will test tomorrow your version
you should let the minimum freq at 480
fingertrigger
Forum Posts: 13
501
2012/06/30 - 22:52
New version still does not autoconnect to wifi 🙁
I have to click "wifi settings" in preferences in order to get connected. Same with rev13.
502
2012/06/30 - 23:56
you are the only one whit this problem, provide an adb logcat when the tablet tries to autocoonect to the wifi
try also from your wifi rooter to change the channel, and put the encryption to wpa/wpa2
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
503
2012/07/01 - 07:53
For the first time it is normal to do so, but then it should auto-connect. It does always for me. Maybe there are two WiFi networks it could connect to and it doesn't know which one?
AFAIK the tablet uses the same power in the range from 480 to 600 MHz, but it responds noticeably faster now, everything else works fine. Or am I wrong? Atleast from my tests the battery did not drain.
504
2012/07/01 - 11:02
from what i know bettwen 120 mhz and 480 the processor uses the same voltage, higher then 480 the voltage is the same as it is on 800
for me it works fine with 480 😀
in 2 3 weeks i will have the 7c g3 😀
ray
Forum Posts: 27
505
2012/07/08 - 01:56
Re; ClockworkMod recovery and GPS workaround. running Nano CFW rev13b
I do not have easy access to a PC, can I cold boot into cwm, if so how? Power and volume down appears to take me into fastboot. I'm concerned that at present I can only get into cwm from settings and if I do something stupid my recovery is on sd.
GPS; I have tried VODAFONE KEYRING RECIVER 51 CH. BLUETOOTH GPS SAT NAV RECEIVER 4 LAPTOPS MOBILES - Ebay around £10, with Bluetooth GPS Provider app, very accurate and quick refresh with google maps and CoPilot. I am not with vodafone, the receiver works without any software from them, but does use a lot of battery.
morpheus972
France
Forum Posts: 11
506
2012/07/09 - 07:23
Hello guy!
I just looked at the arnova website in order to compare the 7c g3 and the 7c g2... On their site, there's not a lot of differences... Will you compare them, to port ICS on the g2?
With the 7c g3, we know that the 7c g2 will not be upgraded to ICS... Frown
Best regards.
507
2012/07/09 - 09:08
I will have very soon the 7c g3, i will try my best to do something, the spec are different not the same.
wifi different
cpu different
more ram
different gpu (arnova 7c g2 has the 200 series, the 7c g3 has the 205 series)
each difference from above means different drivers, and since we do not have source files from arnova, the drivers can not be compiled from thin air.
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
508
2012/08/16 - 09:54
Hi folks,
rev14 is now online. This is the last planned release. I still own the 7CG2, but I already got a Galaxy Tab 2, which I'm currently hacking on... I may provide bug fixes and stuff for this CFW, but don't expect anything great anymore.
Thanks Received: 3177
509
2012/08/16 - 09:58
Thanks for your continued and excellent work you provided on the Arnova 7c G2 Wink
Have fun with your Gtab 2 !
Edit: I've edited your first post so your download link really shows as a link.
I've also made an archive of your files, just to store a copy.
macola.hr
510
2012/09/12 - 21:06
I know that there is no new version but for now rev14 works excellently.
Setialpha thanks for the effort invested in this all together.
Without these ROMs these tablets are not worth anything, this looks much better and much better work.
Market was my biggest problem, but I see that there's a lot of better options than the stock ROM.
Currently Online: WhiteD2125
67 Guest(s)
2 Guest(s)
Devices in use: Desktop (64), Phone (4)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
