Lost password?
The forums are currently locked and only available for read only access
Nano CFW rev14 [2012.08.16] Android Market and DC2SD
This topic is locked
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
451
2012/04/07 - 00:11
Not 100% sure, I guess sunday. I have not yet looked into the Wifi/3G issues posted above.
Allow me that bit of arrogancy: lol Ubuntu - real men use Debian Wink
I'm currently testing VLC - see: http://forum.xda-developers.com/showthread.php?t=1517415
Flash 11 you posted works fine... except it lags. Maybe because I have hw-rendering enabled?
christophe27
Forum Posts: 27
452
2012/04/07 - 19:45
Hi Setialpha,
I wanted to give you more info about what I could test on the tablet.
I am using version 13b
* concerning gps :
--> i tried to modify loc_param.ini in the /etc rep.
Modified traking/oneshot with no improvment.
I switched default/standalone with no result either.
After re-thinking, I think that gps malfunction has nothing to do with 3G/Wifi. It looks rather like the daemon crashes or so after a while. No way to have it restarted on tracks after : needs restarting the tablet.
* concerning Wifi :
never starts on its own, and always need to get into the param menu to have the wifi service get its address.
* concerning "your" personal dropbar : I think it does not reflect the status of the devices accuratly. And it does not swith devices on/of corrctly either. It looks like it loses track of the dev status after a while. As if it was toogling dev on/offf and would miss a step. This also confused me when I was working with gps trying to figure out the context.
* don't you have troubles with com.android.vending ==> couldn't buy anything - good for my budget.
I looked into the filesystem, but could not find where the processes where started (like with linux : runlevels or init scripts). So for instance, what it the gps deamon ? when does it start ? I would like to help but I can't do much. Where can I find some info ?
Thank you
fingertrigger
Forum Posts: 13
453
2012/04/08 - 11:35
Just wondering: is there any way to make camera to work in external apps? Built-in photo and video works well, but all apps I'd tried from Market (barcode readers, "red light" for instance) display various "camera error" dialogs and refuse to take pictures.
Thanks Received: 268
454
2012/04/09 - 13:26
christophe27 said
Hi Setialpha,
* concerning gps :
* concerning Wifi :
Thank you
I thinkg that you can restart the deamon from the terminal, i`m not sure about this.
455
2012/04/09 - 16:33
Some Frameworks files cooked by me, maybe you like one and you will implement `it on the rom.
Link:
http://www.mediafire.com/?peqgre6y2t0i1zv
You can flash them via recovery, all of them include windows animation from ICS
456
2012/04/09 - 21:46
This a new framework, it looks really nice 😀
http://www.mediafire.com/?x2j57qzv3iqosag
give me some apps to test in the some conditions to see if i will have the same results regarding the flash player.
457
2012/04/10 - 16:40
I have some tun.ko modules for test
If you need them i can upload them.
christophe27
Forum Posts: 27
458
2012/04/11 - 14:02
Hello globula
With the tun.ko-installer from market, i already have a tun.ko module loaded (insmod) and runnig. Is hared it in the tun.ko rep. are you offering smthg different? I can upload that version too. (But the web site did not take it this time...)
459
2012/04/11 - 14:20
your tun.ko is working ?
christophe27
Forum Posts: 27
460
2012/04/12 - 01:44
Hi Globula
Yes, that tun.ko (that i use) does works :
* loads fine with insmod
* works together with openvpn, get vpn started over 3G and wifi, and through droidwall
* gets to sleep, wakes up
(* openvpn manages password protected SLL keys, loads automagically tun.ko and reconnects by itself)
I will upload tomorrow if you want it (no access 4 tonight)
chris
461
2012/04/12 - 13:42
then upload`it and sethialpha will add it to the rom.
zanty69
Italy
462
2012/04/13 - 11:28
Very Very GOOD JOB setialpha. Your firmware is beautifull.
I make now a donation to you. Thank you.Laugh
christophe27
Forum Posts: 27
463
2012/04/14 - 00:34
Hi Globula,
here is the module http://www.mediafire.com/?q1j04ichr9pv2p0
I first installed it with the "tun.ko installer" app from market. I don't know if that app did anything
Now, I only use openvpn (app) to get the module loaded at when it starts (tun.ko anywhere on sdcard, loaded with insmod as explained above).
I would be insterested to know if the module works for you too, and if it can be added to the rom too.
Chris.
PS:
* any news about the GPS on your side ? Mine is still working now and then - no reliability.
* wath is the name of the 3G deamon you told about ?
thanks
Edit by globula: I re-uploaded the file on mediafire.
464
2012/04/14 - 00:52
use media fire, it is easier :))
tell me from which country you are, i will try to make a gps.conf for you.
465
2012/04/14 - 20:25
Sethi, maybe can you add this in your next build
http://forum.xda-developers.com/showthread.php?t=1561806
can we do something same to our tablet ?
http://forum.xda-developers.com/showpost.php?p=22157605&postcount=25
so we can asign a bigger space for system, which is now limited to 120mb?
96 Guest(s)
Devices in use: Desktop (84), Phone (12)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
