MTD-Utils / re-partitioning MTD
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/15 - 18:35
The MTD (the internal NAND (memory)) of the 7cG2 can be runtime-repartioned.
It's actually just one chip with virtual partitions-boundaries, those can be controlled via kernel command-line.
Here's the example I'm currently having running on my tablet:
Original MTD:
mtd-list
boot 0x0000044E0000 0x0000049E0000
system 0x0000049E0000 0x00000C1E0000
cache 0x00000C1E0000 0x00000C5E0000
misc 0x00000C5E0000 0x00000C6E0000
userdata 0x00000C6E0000 0x00001DFE0000
persist 0x00001DFE0000 0x00001E1E0000
recovery 0x00001E1E0000 0x00001E6E0000
content 0x00001E6E0000 0x00001FFE000
ls /dev/mtd/
mtd0    mtd1    mtd2    mtd3    mtd4    mtd5    mtd6    mtd7
mtd0ro  mtd1ro  mtd2ro  mtd3ro  mtd4ro  mtd5ro  mtd6ro  mtd7ro
Now I have running:
mtd-list
system 0x0000049E0000 0x00001DCE0000
misc 0x00001DCE0000 0x00001DDE0000
content 0x00001E6E0000 0x00001FFE0000
ls /dev/mtd
As you can see, there are no cache and userdata partitons anymore (as I have them on my SD-Card, I can safely give the space to system partition as it's entirely unused).
I have not yet removed content partitions, as I don't yet know how well those changes work with fastboot, so I left recovery and content untouched to not mess things up.
Now for the experts:
mtd-utils cross-compiled for 7c g2: http://www.nanolx.org/downloads/mtd-utils-1.4.9+20120214-arnova7cg2.tar.xz
mtd-list (a script to list all mtd partitions with start and end point): http://www.nanolx.org/downloads/mtd-list
mtd-calc (a script to calc the size of a parition (usage: mtd-calc endpoint startpoint)): http://www.nanolx.org/downloads/mtd-calc
Last but not least the command I used to create the boot.img:
mkbootimg\
    --kernel nano-boot.img-kernel\
    --ramdisk ramdisk.gz\
    --cmdline "console=ttyDCC0 androidboot.hardware=qcom mtdparts=msm_nand:5120k@0x0000044E0000(boot),
412672k@0x0000049E0000(system),1024k@0x00001DCE0000(misc),
2048k@0x00001DFE0000(persist),5120k@0x00001E1E0000(recovery),
25600k@0x00001E6E0000(content)"\
    --base 0x00200000\
    -o custom-boot.img
the '--cmdline ...' MUST be in one line!
So... let the games begin 🙂
tremendo
Forum Posts: 42
2012/02/16 - 14:01
this can come in handy at some time... thanks for the research!
myguess is that /content is used by appslib.. no clue about persist.
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/16 - 19:24
It's not adopted by fastboot. I guess it's because the built-in partition table is used in the very very early process. Once the kernel is loaded the modified is used. This can result in /system/bin/ beeing out of place... (say it's outside the area /system normaly is)... so /system should still be flashed using fastboot not recovery.
Any other operation in running system/recovery is just fine of course.
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/16 - 20:14
I have a question.
On smartphone for changing mtd parition you have to s-off your peripheral, is the same for tablet?
After you had s-off the phone you could change mtd partition by creating a txt file and put it on sd card.
The file is like this: mtdpartmap.txt -> "140 25" which is 140 system and 25 cache
After that you should flash a new rom and the mtd partition size change..
Is the same for tablet?
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/16 - 20:22
... that would work in theory, but those scripts need to be adjusted to take all partitions in account. But this s-off scripts do nothing else than create the --cmdline for the kernel and re-build the boot.img and flash it.
So I did not bother with it and created the cmd-line on my own using mtd-list and mtd-calc scripts (and /dev/brain), building boot.img is just a simple 'repackboot'.
Results:
Fastboot uses built-in partition table - does not use --cmdline - if /system begins where it original begins fastboot flashes fine.
tremendo's recovery does properly flash update.zip with modified MTD partition table.
tremendo's recovery does NOT properly flash using 'flash_image MTD IMG'
So... if we could get fastboot to recognize the changed structure... but I guess that would require a self-compiled kernel with the changed layout built-in.
@tremendo: yes /content is for appslib. but: since recovery must be flashed from fastboot I could only reisze the recovery MTD until the end of the MTD, but not move it.
88 Guest(s)
Devices in use: Desktop (75), Phone (13)
swan12
heftpflaster
