ice cream sandwhich / cm9
Thanks Received: 264
2012/02/27 - 18:48
so we gonna give up, or continue with some builds, tests ?
2012/03/13 - 18:26
I`ve tested today a rom from lg p500
A ics one, using nano boot image
and i had this error
  at java.lang.Thread.run(Thread.java:1019)
E/NetdConnector(  152): java.io.IOException: No such file or directory
E/NetdConnector(  152):         at android.net.LocalSocketImpl.connectLocal(Nati
ve Method)
E/NetdConnector(  152):         at android.net.LocalSocketImpl.connect(LocalSock
etImpl.java:238)
E/NetdConnector(  152):         at android.net.LocalSocket.connect(LocalSocket.j
ava:98)
E/NetdConnector(  152):         at com.android.server.NativeDaemonConnector.list
enToSocket(NativeDaemonConnector.java:99)
E/NetdConnector(  152):         at com.android.server.NativeDaemonConnector.run(
NativeDaemonConnector.java:83)
E/NetdConnector(  152):         at java.lang.Thread.run(Thread.java:1019)
E/NetdConnector(  152): Error in NativeDaemonConnector
ve Method)
etImpl.java:238)
ava:98)
I/Netd    ( 1113): Netd 1.0 starting
E/SocketListener( 1113): Obtaining file descriptor socket 'dnsproxyd' failed: No
E/Netd    ( 1113): Unable to start DnsProxyListener (No such file or directory)
E/NetdConnector(  152): Communications error
ve Method)
etImpl.java:238)
ava:98)
ve Method)
etImpl.java:238)
ava:98)
PerfectPeso_v2.2 is the name of the rom
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/03/13 - 18:40
I'm working 24/7 on a port
2012/03/13 - 19:07
you should use the work from the lg p500 because u tried also another rom, and the installation worked, i even had boot animation on, but the same thing with some apps
http://pastebin.com/5FhAuvTw
85 Guest(s)
Devices in use: Desktop (68), Phone (17)
heftpflaster
rk.13
