ice cream sandwhich / cm9
tremendo
Forum Posts: 42
2012/02/25 - 11:03
has anyone tried running http://galaxyics.com/ ? you might have flash it manually because it's for the samsung ace, which is apparently msm7x27 . going to try it in a couple of days..
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/25 - 11:39
Asap i will flash it.
Thanks Received: 264
2012/02/25 - 12:05
is the link working for you daniel ?
Le: Nvm now its working, but very slow !
2012/02/25 - 12:28
it`s stucked !, damn
but arnova 7c g2 has 7627 processor, or at least on mine it shows that....
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/25 - 12:31
Link works fine!
tremendo
Forum Posts: 42
2012/02/25 - 14:55
globula: you may want to try running adb logcat while it boots -- if it shows anything there's a good chance it can be made to work. Do you get to the "android" logo screen?
daniel: i thought so too, but arnovatech.com says the c7g2 is msm7227 based. anyway they should be compatible. they definitely have the same instruction set and gfx coprocessor. only major difference is screen resolution but that should be easy to fix..
2012/02/25 - 16:31
i tried with daniel to flash the rom, we tried first with the ace.zip and it installed ok, with no erorrs but the problem i think it is the fact that the rom is not rooted, i say this because the result was
C:\Android\android-sdk\platform-tools>adb logcat
- exec '/system/bin/sh' failed: No such file or directory (2) -
after that we tried with cm7, with a build from 2.3.7
http://narod.ru/disk/31653998001/update-cm-7.2.0-RC0-GalaxyAce-KANG-signed.zip.html
and the result was
http://www.picz.ro/pictures/b7be4407802480f6c2c0198c89798900.jpg
Now i will want to try to put the ace.zip in the android emulator the see if i can make`it rootable and then with a recovery to obtain a rooted back-up.
I dont know if this can be done, because i`m new to the android area.
2012/02/25 - 22:40
i did also a back up with the recovery tool and the data obained looks like this.
http://www.picz.ro/pictures/f2c454f2c49147af6e9b7702417bdaed.jpg
It`s very strange because the data file has 80 mB, and the system only 5kB
Could the data be actually the system ?
2012/02/25 - 23:24
C:\unyaffs_files>unyaffs C:\unyaffs_files\data.yaffs2.img
cygwin warning:
  MS-DOS style path detected: C:\unyaffs_files\data.yaffs2.img
  Preferred POSIX equivalent is: /unyaffs_files/data.yaffs2.img
  CYGWIN environment variable option "nodosfilewarning" turns off this warning.
  Consult the user's guide for more details about POSIX paths:
    http://cygwin.com/cygwin-ug-net/using.html#using-pathnames
end of image
This is the content of the data.yaffs2.img obtained by instaling the ace on my arnova and after that using recovery mode to do a back up.
http://www.picz.ro/pictures/a7df98f328d7597fb00efd0bc9f805fb.jpg
For me it looks a little bit like the system.img from arnova, though are many diferences
2012/02/26 - 09:01
i did some research and zte blade was ported to cm9
here is the topic http://android.modaco.com/topic/351670-ics-cm9-coldfusion-for-the-zte-blade-rom-updated-2302/
Also htc wildfire s was ported to cm7 and cm9
These devices have similar specs to arnova 7c g2
Arnova 7c g2 has a 7627 qualcomm processor
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/26 - 15:35
now it works!
mmfd
2012/02/26 - 16:00
Quick question: How far are we from an ICS rom for our Arnova?
2012/02/26 - 16:10
Far ?
Considering that galaxy ace was not fully ported on cm9, it will take a wile, and even so we are not 100 percent sure that we will be able to port`it
2012/02/26 - 16:11
DanielVd said
now it works!
what works ?
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/26 - 16:55
globula_neagra said
DanielVd said
now it works!
what works ?
it boot now, adb logcat show some text, but the screen is black
86 Guest(s)
Devices in use: Desktop (69), Phone (17)
heftpflaster
rk.13
