Hi Globula_negra,
A year ago you said you were working on a last version of your test-v3.zip
Did you finally publish ?
And another question please : which files are configuring the gps system ? I worked on it a year ago as well, thought it wall gps.conf and loc_parameter.ini, anf got it working thanks to you.
But finally, it (gps) is not working agin after re-installing testv3. So I guess I have to look into gps again.
could you please help ?
thank you
christophe
http://www.mediafire.com/?ib8l04jxds55xv4
This was the last version, i just installed this version on a person tablet couple of days a go and the GPS was fine 7-10 satellites available.
Yes, those are the files needed to config the gps.
sammonsmx, stefan1kmHi Globula,
I worked, again and again on the gps problems.
I finally got a second tab a month ago, reinstalled everything (data, params and FW) exactly the same.
And gps worked.
It seems the first tab and a failling gps system. I never thought of it, thinking my flashing/bricking and else was responsible.
I finally had gps.conf and loc_params like publiched on page 7.
Thank you for you previous answers.
PS : I might get on 7cG3 soon...
If you get it around 200 euros/pounds/dolars, i suggest to get a Nexus 7 3g refurbished
2012/05/05
I have had about 5 7cg2's now. The GPS and wifi modules seem to vary in strength from one device to the next. Of course I've held on to one that has strong wifi and GPS, though I have to say I'm looking for a model that supports newer than gingerbread. I have used the testv3 rom for as long as I can remember, along with the Go Launcher.  Huge thanks to Globula Neagra. It has been really rather good and I am still very fond of it. I still have a couple of spare batteries and other parts if anybody is in need. I'm not a software guru but do have much experience with the 7c g2 hardware.
2012/01/25
I don't know if this forum gets looked at often..
but i have flashed clockwork mod recovery, but only way i can access it is by choosing about phone system updates on the tablet.. the ADB no longer seems to work with the clockwork mod installed. i am concerned, that if i flash an image that does not have this about phone system updates function, i cannot access clockwork mod.. have i done some thing wrong or is there an alternative way to access clockwork mod.. It worked previous, as my device managea said ADB device in it when i held the volume minus button and power... is isthis safe ?
Currently Online: Azabatxe1
154 Guest(s)
Devices in use: Desktop (147), Phone (8)
jacksonrid
usdown
ibob64
