Glob_Be_One ROMS
Related Tags
sammonsmx
Forum Posts: 36
91
2012/05/25 - 23:31
I just went for a spin in the car.  Sygic 11.2.3 running on my C7G2 as well as on my ZTE Blade.  Both devices work fine - the arnova voice nav was about 2 seconds behind the blade, but the maps updated just about in sync.  No problems at all.  I run Navigon 2.5.1 on the blade, on android 2.2, but that wont run on Android 2.3.
christophe27
Forum Posts: 27
92
2012/05/26 - 10:44
Hi glob, hi sammonsmx
I don't share your opinion. The gps gets a quick fix, but tracking is not always working (still) and somerimes gps won't wale up !!!
I mean gpsrest for exemple won't catch a single sat... and i have trouble to start/ stop the deamon
I trief to use glob's settings from May 15th but same (or worse)...
here are my settings, i find them simple and efficient. I think problem is with the fw, or some init/conf file of other kind
chris
christophe27
Forum Posts: 27
93
2012/05/26 - 10:46
Gps.conf :
NTP_SERVER=fr.pool.ntp.org
#NTP_SERVER=europe.pool.ntp.org
#NTP_SERVER=de.pool.ntp.org
XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
XTRA_SERVER_4=http://xtra4.gpsonextra.net/xtra.bin
# DEBUG LEVELS: 0 - none, 1 - Error, 2 - Warning, 3 - Info
# 4 - Debug, 5 - Verbose
DEBUG_LEVEL = 5
# Intermediate position report, 1=enable, 0=disable
#INTERMEDIATE_POS=0
INTERMEDIATE_POS=1
# Accuracy threshold for intermediate positions
# less accurate positions are ignored, 0 for passing all positions
ACCURACY_THRES=3000
##### AGPS server settings #####
# FOR SUPL SUPPORT, set the following
#SUPL_HOST=supl.google.com
#SUPL_PORT=7276
#SUPL_SECURE_PORT=7275
#SUPL_NO_SECURE_PORT=3425
SUPL_HOST=supl.nokia.com
SUPL_PORT=7275
#SUPL_HOST=geoloc2.sfr.fr
#SUPL_HOST=agpss.orange.fr
# FOR C2K PDE SUPPORT, set the following
# C2K_HOST=c2k.pde.com or IP
# C2K_PORT=1234
# EXTRA SETTINGS
CURRENT_CARRIER=common
PHONE_TYPE=UMTS
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_SSL_ENABLE=FALSE
DEFAULT_USER_PLANE=TRUE
#ENABLE_WIPER=0
ENABLE_XTRA=TRUE
##REPORT_POSITION_USE_SUPL_REFLOC=1
##START_MODE=WARM
##OPERATION_MODE=MS-ASSISTED
# AUTRES SETTINGS
#QOS_ACCURACY=50
#QOS_TIME_OUT_AGPS=95
#QOS_TIME_OUT_STANDALONE=80
#QosHorizontalThreshold=1000
#QosVerticalThreshold=500
#AssistMethodType=1
#AgpsUse=1
#AgpsServerType=1
#AgpsServerIp=3232235555
christophe27
Forum Posts: 27
94
2012/05/26 - 10:49
Locparam.ini:
# Copyright (c) 2007 QUALCOMM Incorporated.
# All Rights Reserved. QUALCOMM Proprietary and Confidential.
# Use logcat
use_logcat = 1
#define LOC_EVENT_PARSED_REPORT 1
#define LOC_EVENT_SATELLITE_REPORT 2
#define LOC_EVENT_NMEA_REPORT 4
#define LOC_EVENT_STATUS_REPORT 8
#define LOC_EVENT_NI_NOTIFICATION_VERIFICATION 16
#define LOC_EVENT_PREDICTED_ORBITS_REQUEST 32
#define LOC_EVENT_ASSISTANCE_DATA_REQUEST 64
#define LOC_EVENT_LOCATION_SERVER_REQUEST 128
#define LOC_EVENT_IOCTL 256
event_mask = 65535
#define LOC_NMEA_MASK_ALL 65535
#define LOC_NMEA_MASK_GGA 1
#define LOC_NMEA_MASK_RMC 2
#define LOC_NMEA_MASK_GSV 4
#define LOC_NMEA_MASK_GSA 8
#define LOC_NMEA_MASK_VTG 16
nmea_sentence_mask = 31
#LOC_IOCTL_LOCK_NONE 1
#LOC_IOCTL_LOCK_MI 2
#LOC_IOCTL_LOCK_MT 3
#LOC_IOCTL_LOCK_ALL 4
engine_lock = 0
#1 - DEFAULT, 2 - MSB, 3 - MSA, 4 - Standalone
#5 - Speed optimal, 6 - Accuracy optimal, 7 - data optimal
operation_mode = 4
#0 - tracking, 1 = singleshot
fix_session_type = 0
#time between fixes (in seconds)
time_between_fixes = 6
#Accuracy threshold (in meters)
accuracy_threshold = 255
#Fix timeout (in seconds)
fix_timeout = 60
#XTRA related parameters
enable_auto_download = 1
auto_download_period = 1
#xtra1.gpsonextra.net
xtra_server_addr = 65.39.128.135
# Data request reply support
data_request_reply = 1
# UTMS PDP profile, 0 for default
umts_profile_number = 0
# APN name, NULL for default (no quotes)
apn_name = NULL
sammonsmx
Forum Posts: 36
95
2012/05/26 - 15:02
Will continue to test GPS over the next week.
This Testv3 ROM dos not show Tethering in the networks menu. Should it be there?
Thanks Received: 264
96
2012/05/26 - 15:51
no, but the rom supports tethering.
sammonsmx
Forum Posts: 36
97
2012/05/26 - 16:19
Thanks, so it does - used Wireless Tether app.
achihj
98
2012/05/28 - 12:35
Hi i wanted to use DroidVPN but it is looking for the tun.ko module? Where could I get that?
I posted here because I'm currently using this rom
Thanks,
99
2012/05/28 - 12:56
search on the market tun.ko installer
achihj
100
2012/05/28 - 18:18
It says the downloaded module is incompatible...
christophe27
Forum Posts: 27
101
2012/06/01 - 00:26
I posted a working module on seti's rom ver 13b. I had the same pb, found a working module and uplozded it
See other thread around page 25
102
2012/06/12 - 21:19
I will post my last version in a few days.
Solved some bugs on audio side
Better gps/updated apns, host, spn files.
Little things, not to much, since we do not have the source files.
I will stop developing for the tablet, at least for the moment.
I bought a Htc one X 🙂 and i will buy also the SGS3 so the brain will concentrate on other things.
In this post you will find some new gps settings, that personalized for europe/asia/america
http://www.arctablet.com/blog/forum/arnova-7c-g2-android-firmware-development/useful-stuff/
people allready reported that the gps configs are really good.
Thanks Received: 3169
103
2012/06/13 - 22:49
Thanks for the continuous support with your firmwares and the help you provided globula_neagra, it has been a great support for many forum users here. I understand it's time to move on as the 7c G2 is getting a little outdated now and there are very little chances to get it up to speed with ICS and latest goodies.
Good luck with the last firmware build and for future work on HTC One and SGS3 Wink
christophe27
Forum Posts: 27
104
2012/07/14 - 20:25
Hi glob'
much thanks for your work indeed
you said you'd post your last post/rom before stopping development on 7cG2. Where did you post it, can we benefit from it ?
thanks.
ray
Forum Posts: 27
105
2013/02/07 - 23:34
Hi globula_neagra,
You installed Seti's rom 13b on my 7cG2 last year using team viewer. I would now like to install your rom to the same 7cG2.
1. The link to your latest rom V3? at mediafire says it is owner only. Where can I find your latest version?
2. Am I correct in understanding that I can download it to sd as a .zip file and then install it using my current cwm recovery after deleting everything cwm will allow me to?
Currently Online: robertbill
164 Guest(s)
Devices in use: Desktop (157), Phone (8)
robertbill
valantains26
BetoGamerYT
kaantopal
jkt3st3r
Keo1
