Glob_Be_One ROMS
Related Tags
recarei2
portugal
Thanks Received: 264
77
2012/05/16 - 00:49
mate a link towords flash player where i can download it
recarei2
portugal
recarei2
portugal
79
2012/05/16 - 00:58
ok
jajonesss
Forum Posts: 13
80
2012/05/16 - 01:05
globula_neagra said
the video are working, i just used the tablet 10 minutes again, you need to get the video in full screen and disable the hd, after that te video will start, or you can use a older youtube version and you will not need to do this
is not my fault, but the tablet can not play hd videos, and all the videos from the youtube 2.4.4 start in hd when you play them.
thanks,
I disable the HD and it works perfectly.
81
2012/05/16 - 01:07
Use this version is the same, but is smaller
http://www.mediafire.com/?i91d3c4h9ridida
destructa
Forum Posts: 17
82
2012/05/19 - 16:23
Hi, before I go and install this Rom does it use the SD Card as RAM/Storage as the previous ROM i flashed with did.  Also does the 3G work (using 3 UK mobile broadband sim at present) and does the GPS work?
83
2012/05/19 - 17:46
no, this ROM does not have the apps and data to sd enabled
nobody has requested that till now
The 3G works, I am in UK also and i am on giffgaff)
Gps works, there are 2 settings provided, mine and sethialpha gps config.
destructa
Forum Posts: 17
84
2012/05/20 - 00:06
Any chance of that happening in a future ROM?
85
2012/05/20 - 00:11
it depends on the number of requests
i also need to learn more about this 🙂
achihj
86
2012/05/24 - 20:14
Hi, i can't find a tutorial on how to install this rom.. could anyone help me? dont have team viewer..
and also i think your gps.conf worked but my location is off by miles, as in province miles away.. i'm from the philippines btw.
87
2012/05/24 - 21:41
flash the cwm recovery http://www.nanolx.org/downloads/trenano-recovery-nosd.img via fastboot
after that boot the device normally
put the rom on the sd card
then use adb with this command adb reboot recovery
a blue menu will appear you need either to press 27 times a volume key till you see back menu enabled on the screen
or to press in this order the voulume keys + - +
after that you do the selections with the search buton, you perform a factory reset, a system format, and then you flash the new rom.
achihj
88
2012/05/25 - 17:46
Got it working now,
Thanks!
sammonsmx
Forum Posts: 36
89
2012/05/25 - 19:56
Flashed testv3 - will try gps using sygic
90
2012/05/25 - 20:30
sygic does not work on arnova, or at least the version that i had
Currently Online: GUCHEZ MICHEL
86 Guest(s)
Devices in use: Desktop (80), Phone (7)
behzad
84000
Kemoty
wagle
etan
KuPuK
