Glob_Be_One ROMS
Related Tags
cror81
Toulouse, France
61
2012/05/14 - 21:53
globula_neagra said
provide the apn settings from your provider
i will have a look to the text to speach installer
Hello, sorry for the delay I was kinda busy
TextspeechInstaller finaly been installed properly after a few more attempts
For the APN I entered manually the parameters, all seems to work now.
Thanks again for your help
christophe27
Forum Posts: 27
62
2012/05/15 - 00:01
hi glob
Indeed, i use v13b of seti. But you said you re using same gps engone, don't you?
Can you punlish your config version online on the forum ? Troubles with mediafire. Thx
Chris
Thanks Received: 264
63
2012/05/15 - 00:42
NTP_SERVER=1.pool.ntp.org
NTP_SERVER=0.europe.pool.ntp.org
NTP_SERVER=1.asia.pool.ntp.org
NTP_SERVER=2.north-america.pool.ntp.org
AGPS=http://xtra3.gpsonextra.net/xtra.bin
XTRA_SERVER_1=http://xtra3.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=http://xtra4.gpsonextra.net/xtra.bin
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_USER_PLANE=TRUE
DEFAULT_SSL_ENABLE=FALSE
INTERMEDIATE_POS=1
QOS_ACCURACY=50
QOS_TIME_OUT_AGPS=95
QOS_TIME_OUT_STANDALONE=80
QosHorizontalThreshold=1000
QosVerticalThreshold=500
AssistMethodType=1
AgpsUse=1
AgpsServerType=1
AgpsServerIp=3232235555
SUPL_HOST=FQDN
SUPL_PORT=7276
SUPL_SECURE_PORT=7275
SUPL_NO_SECURE_PORT=3425
SUPL_TLS_HOST=FQDN
SUPL_TLS_CERT=/etc/SuplRootCert
ACCURACY_THRES=3000
CURRENT_CARRIER=common
PHONE_TYPE=UMTS
another download link
http://www.2shared.com/file/BNzF6QAU/gps.html
I would preffer that you use the one from the link, because from what i noticed, you need a special text editor that preserves some code, and notepad from windows does not do that.
The Ntp servers can be changed an configured to you contry (use google to find out ntp servers in your contry)
it is supossed if you use those from your contry you will get a better and faster fix
i got today a fix even in 10 seconds with this config. (not a full fix, just one with 3 satelities, for an accurate one you need at least 5, i got a full gps fix in 20-30 seconds)
i forgot, i added a certificate in etc, and is only in testv3 build (check post 3 from the begging of the topic)
recarei2
portugal
64
2012/05/15 - 01:23
I have installed v13b (NOSD) of Seti. but wanted to use yours. how can I install? to update the system or fastboot? tSmilehank you
65
2012/05/15 - 01:37
you need to first to put the rom on the sd card
after that go to settings/about phone/system updates
and the phone will enter in recovery mode
go to mounts and storage and select format system, after that go back to the main menu, and slect wipe data/factory reset, to also this
then go to install zip from sd card and then chose zip from sd card, select the rom, and flash it, reboot the system.
recarei2
portugal
66
2012/05/15 - 14:38
Hello
I am not able, until the recovery mode fine. Then select any option that I can not do anything. Or power off.
67
2012/05/15 - 14:50
you need to enable the menu in recovery, press the volume key + for 27 times, and after that you can to selections with the search button
68
2012/05/15 - 21:32
New launcher 🙂
http://www.picz.ro/pictures/bb7940655e56e7e21b3f47e2b1df5ed1.pngImage Enlarger
cror81
Toulouse, France
69
2012/05/15 - 22:17
Hi GPS works fine even with old config file
One odd thing, the tablet was stuck in 2G, I had to check in then out the "use only 2G network" check box in order to enable 3G connexions.
For all other aspects the rom is awesome, tablet is quick and stable. I'll look forward for updates 🙂
recarei2
portugal
70
2012/05/16 - 00:19
already installed. is very good.
 but I think the flash player and the net was faster in the old rom. (nano v13b)
 thank you
71
2012/05/16 - 00:32
what flash player did you used ?
recarei2
portugal
72
2012/05/16 - 00:36
flash player 11 v11.03.153_armv6
had the same
73
2012/05/16 - 00:39
can you give a download link for that ?
jajonesss
Forum Posts: 13
74
2012/05/16 - 00:42
Dont think the youtube app work on this rom globula, or maybe its something with my tab but no video will play.
75
2012/05/16 - 00:45
the video are working, i just used the tablet 10 minutes again, you need to get the video in full screen and disable the hd, after that te video will start, or you can use a older youtube version and you will not need to do this
is not my fault, but the tablet can not play hd videos, and all the videos from the youtube 2.4.4 start in hd when you play them.
64 Guest(s)
Devices in use: Desktop (55), Phone (9)
swan12
heftpflaster
