Glob_Be_One ROMS
Related Tags
Thanks Received: 264
46
2012/05/13 - 12:01
do you reffer to gtalk ?
the gps is exactly the same as on sethialpha now
is gps.conf and loc param
christophe27
Forum Posts: 27
47
2012/05/13 - 18:29
Hey Glob,
concernant GPS, I am not refering to any app in particular.
I just noticed the gps works with nano ver 13b, but only gets 1st fix. Never tracks....
This is anoying with ware, googlemaps, or any other gps driving app.
I thought it had to do with loc_param.ini => single shot or tracking. I switched it, start over, but got no difference.
Btw, how do you test your gps and different options : how do you restart the gps deamon ?
thx - Chris
48
2012/05/13 - 18:56
do you get that result with my rom, or with sethialpha`s rom ?
i tested the gps with google maps
if you toggled the gps settings from the status bar, you can restart the gps deamon
49
2012/05/13 - 19:21
Guys i made a pack of apps for this rom
link http://www.mediafire.com/?7dz23hdjsqfurju
50
2012/05/13 - 22:30
guys i made this gps.conf and it works great, you can include it in your roms just by using file explorer, and copy paste`it over the old one that is in system/etc
link http://www.mediafire.com/?4qz6arz6qxqxrv3
it uses the 3g, wifi, gps, everything to get a perfect location
Also if more of you can test it it would be nice to hear some results
jajonesss
Forum Posts: 13
51
2012/05/14 - 07:45
Hi globula_neagra,
I am using the latest version of your rom, its very good. I love it.
Last night I installed the new gps.cont and gps kind of work now. The problem is it show my location about 70 miles from where I am. I also installed gps test and maps crashed everytime until I unstalled gps test. Maps show my current location as accurate to 99900 mitres.
52
2012/05/14 - 08:45
i will post a guide in the next days which will help you all to make yourself a gps setting configured for your country, now the gps is configured for the hole world
but even so, i get a gps fix in uk in 30 seconds- maximum 1 minute (and this is in the house, not outside)
the location is shown like that because the gps is not fully fixed, and you get info only from one or 2 satellites
ukoeni
53
2012/05/14 - 17:09
Hallo I´m new in this forum.
I like the very good work u do all for this tablet.
Now my question. I want to install v3. but the recovery mode (installed system nano cfw) doesnt work. always when i click install from sd card there comes a hat on the screen an nothing happens. (also i cant use wipe cache ....) do i something wrong.
sorry for my english
Uwe
54
2012/05/14 - 17:15
do you have sethialpa rom`s that uses the sd card?
if you don`t have that one
do this
fastboot erase recovery
fastboot flash recovery recoveryfilenameandpath
this is the recovery that everybody use
http://www.nanolx.org/downloads/trenano-recovery-nosd.img
it it does not work
perform a full wipe of the system, that means
fastboot erase boot
fastboot erase system
and reflash all the stuff back from sethialpha
and then try to flash again my rom from recovery
ukoeni
55
2012/05/14 - 20:04
i´ve done everything you wrote but it still doesn´t work. please can you help me again.
56
2012/05/14 - 20:08
send me the pass and id via pm from teamviewer and i will help remotely
ukoeni
57
2012/05/14 - 20:26
ok
recarei2
portugal
58
2012/05/14 - 21:28
Put a video of the installation. Thank youWink
59
2012/05/14 - 21:46
i dont have a such performant camera, and the quaility won`t be good
if you need help, i can help you.
Thanks Received: 3171
60
2012/05/14 - 21:50
I made this video a while ago, it may give some help for the recovery flashing part:
71 Guest(s)
Devices in use: Desktop (61), Phone (10)
swan12
heftpflaster
