ย Please donate to support OMA and CrewRKTablets firmware work, thank you !
Glob_Be_One ROMS
Related Tags
cror81
Toulouse, France
31
2012/05/11 - 19:31
I did it but it had no effect,
The flash still seems to last only a few seconds
Can this be a problem with the zip file integrity?
Would it be possible to flash your system and boot imgs using fastboot?
Thanks Received: 264
32
2012/05/11 - 19:45
can you check your zip file size ?
and also check in adb logcat what error you get
cror81
Toulouse, France
33
2012/05/11 - 19:47
File size is 75509 Ko
cror81
Toulouse, France
34
2012/05/11 - 19:51
adb logcat not responding at all
35
2012/05/11 - 19:54
strange, very strange ๐Ÿ™‚
http://www.mediafire.com/?ib8l04jxds55xv4
try this version, it is the last build
cror81
Toulouse, France
36
2012/05/11 - 20:02
Thanks it will take a while, my internet access is rather slow...
ย
In the meantime I've rebooted the system in recovery to do one more try and got an error while wiping dalvik cache
E: unknown error for path [/sd-ext]
37
2012/05/11 - 20:06
it`s ok that, it performs also a dalvik wipe on the sd card in case you have the ext installed
but i did not told you to perform a dalvik, usually when i flash a new build, i format the system, and performat a wipe data/factory reset and everything works well
but you told me that you want to keep your data, why you don`t try a back`up program like titanium ? and then perform also the factory reset.
cror81
Toulouse, France
38
2012/05/11 - 20:13
The dalvik wipe is requested on the very first post talking about your rom installation.
I already did the factory reset (since i recently lost my sdcard system file it put a lot of mess on my system I wanted to start with both fresh system and data)
The new build is now downloaded i'll use adb to put it one the sdcard then try again
39
2012/05/11 - 20:20
yes, that thing was for the V1 version not for the v2 or v3 ๐Ÿ˜€ anyway, it does not affect in any way the instalation
i hope you will flash it this time ๐Ÿ™‚
cror81
Toulouse, France
40
2012/05/11 - 20:54
It worked. Thanks for your help!!!
I'll give it an extended try this week end and post anything I see
ย
Thanks again
Zenuno
Portugal
Forum Posts: 17
41
2012/05/11 - 21:26
Hi all.
Can you tell me how i install recovery in my Arnova? Embarassed
Thanks in advance.
Arnova 7c G2
42
2012/05/11 - 21:56
install java sdk
android sdk
adb drivers
recovery http://www.nanolx.org/downloads/trenano-recovery-nosd.img
enable usb debugging on your tablet
then use adb
adb reboot bootloader
fastboot flash recovery recovery (full path of the recovery file)
fastboot continue
and you will have the new recovery installed
triin
cror81
Toulouse, France
43
2012/05/12 - 00:24
After a few minutes playing with your rom I have some issues:
- First: textspeechInstaller refuse to install data files
- Second: I have a problem with the APNs (I had the same problem on sethialpha 13b Rom), the tablet does register but data link is not active (I'm using orange France)
ย
Thats all for the moment.
44
2012/05/12 - 01:16
provide the apn settings from your provider
i will have a look to the text to speach installer
christophe27
Forum Posts: 27
45
2012/05/13 - 11:07
Hi glob
Can you explain what you changed concerning gps?
Is it just with gpc.conf and loc_param.ini ?
Does tralking work on your rom ?
chris
93 Guest(s)
Devices in use: Desktop (84), Phone (9)
swan12
heftpflaster
