Glob_Be_One ROMS
Related Tags
lostpenguin
United Kingdom
2012/04/30 - 21:03
Good evening - I have tried CoPilot, Navigon and Google Maps. With 13b it still takes a few minutes to lock onto the satellites and the lock can be lost quite easily on occasions
Thanks Received: 264
2012/05/02 - 00:18
The V3 will have
New 3D drivers
Sense Launcher (modded)
New UI
Market with instant Fix
No Frills CPU control
NotePad
TerminalEMulator
File Expert
Miui Music Player
Sense Clock Widgets
Sense Lock
File Explorer.
Andless
Google Talk
Thx to SimonGabry for his boot img and recovery with the remade mtd
whitewhidow
2012/05/04 - 13:11
When will the new version be up ?   im using nano atm, but want to give yours a try .
Thx
2012/05/04 - 13:38
i hope in this weekend, i need to add a gps fix, test it, and after that i will release`it
whitewhidow
2012/05/05 - 11:10
2 small remarks on V2
1. The device ALWAYS sais usb connected in the top bar
2. Could u include the mobilevikings apn so we dont need to add it ourselves
Thx
2012/05/05 - 12:36
give me the apn settings and i will include it
whitewhidow
2012/05/07 - 15:23
APN: web.be
USER: web
PASS: web
Awaiting new release ...
2012/05/07 - 22:52
I will begin this night to cook the new rom
but because of the limitation of the mtd partition regarding the system size, i will provide additional apps, in a downloadble pack.
whitewhidow
2012/05/09 - 15:17
i will hopefully test it this evening.   changelog?
Another issue with your previous version:
I tried installing chainfire3d, but it would install the driver, it said there was not enough room in /system
So i went into file explorer, and tried deleting some stuff, didnt work,   tried changing permissions on /system, didnt work
Tried updating superuser, didnt work + superuser was missing after failed update
Then re-installed superuser, changed permissions on /system, and isntalled chainfire driver,   so i think something might be wrong with root permissions or something ..
2012/05/09 - 16:42
The sense version or the V1 version ?
Do you have this problem also with this build ?
I tried before chainfire and i did not have that problem
This new version as i said it includes some new tweaks on the gps, apns, spn
It is practically the sethialph`s and simone (a mate from a italian forum) and my rom merged toghether
it includes only esential tweeks, and aps, i will provide the aditional apps in a archive
now i need reviews regarding this new version.
whitewhidow
2012/05/09 - 17:11
it was in the V2
I will (hopefully) test your rom this evening and let u know what i come up with
2012/05/09 - 19:07
tnx mate.
also some tips, when you reinstall superuser, you lose the root capabilities
it is strange what you are saying about the V2, because i had it all this time and it was ok, i mean even yesterday i tried to copy some files, and the root was granted, i could set permisions
perform a data factory reset, and system format to be sure that the rom installs corectly
cror81
Toulouse, France
2012/05/11 - 19:12
Hello
I'm trying to install your rom from recovery is do a dalvik cache wipe using the advanced function then select the testV3zip file to install.
Installation seems quite to quick to be honest and wehn I try to reboot the tablet get stuck onto the arnova logo.
I reinstalled sethialpha's rom using fastboot everything is back on line including my apps (I'm using the nosd version)
I'm surely missing one or several steps.
Thanks in advance for your hints
2012/05/11 - 19:21
do a system format, and data factory reset (if you don`t do it i can`t guarantee that the rom will start)
my boot image is different from sethialpha (more things added to it)
70 Guest(s)
Devices in use: Desktop (64), Phone (6)
swan12
heftpflaster
