Hello Everybody 🙂
This is my first ROM, Has the usually tweaks that you find in setialpha`s rom
New things:
- Redisigned framework
- File Expert (this is the version that lets you to mount the system, it is the last offered by them for free with this option, DO NOT UPDATE IT 🙂 )
- New Launcher (the stock launcher is gone, this is a Sony Experia Launcher, i hope you will like it)
- FlashPlayer (version 10.3)
- BBC Iplayer (version 1.3)
- Music app from ICS
- New 3D Drivers
- Google Market (version 3.5.15)
- Busybox
It is flashable via RECOVERY with a wipe/data/cache/dalvik before the actual flash.
To be implemented or solved
Audio Beats
Gps (i dont use`it so i hope to have some testers :D)
Other bugs related to the 3g side
Tip: The first boot takes longer, but after that the system is superfast 😀
Download Link Glob_BeOne_V1 : http://www.mediafire.com/?viy99bksxr6yqvt
Screens:
Version Glob_Be_One_V2Sense
Changed things:
-added GO Launcher with SENSE look, that supports rotation
-Sense Lock Screen
-Htc Widgets
-Audio Beats Librarys
-Changed the gapps so now it instantly syncs (no more 2 hours delay to get the full market) also there are more apps available so check this new thing
-Removed BBC Iplayer
-Added Youtube.
-Added some more tweaks (more to come in the nest release)
Thanks to tremendo and sethialpha
Link : http://www.mediafire.com/?ad2cno6p54xyhs1
Screens:
Test Version SENSE V3
link : http://www.mediafire.com/?ib8l04jxds55xv4
The usual tweeks
GPS
-the test version 3 has the sethialpha`s gps settings
- i also made a gps.conf which i tested and i can say that it works great
-link for download my gps.conf http://www.mediafire.com/?4qz6arz6qxqxrv3
-you just need to copy paste the new file in system/etc (mount the system read/write before that)
APN`s added
-this should solve some carrier problems, like mms settings/internet settings
SPN added from sethialpa`s rom
Sense Launcher
-i removed the sense lock because it had bugs
Audio Side
-beat audio (better sound)
PACK OF APPS ESENTIAL FOR THIS ROM
http://www.mediafire.com/?7dz23hdjsqfurju
it includes:
-flashplayer 10.3
-new launcher in case you don`t like the sense one
PLEASE PERFORM A WIPE BEFOR YOU INSTALL THIS ROM (format system, and data/cache)
Check also this topic for flash player and other apps and mods that i have tested and work fine on arnova
http://www.arctablet.com/blog/forum/arnova-7c-g2-android-firmware-development/useful-stuff/
Another fine looking Arnova 7cG2 firmware, good job globula_neagra
I'll give it a test these next days.
That option does not work, in apps the rotation should work fine, but the home launcher does not yet have the rotation feature implemented.
I will make another rom in the fallowing days, with a honeycomb launcher
A new version will appear tomorrow with sense 🙂 and some improvements on the marke, it will sync in 5 sec and more apps will be available
88 Guest(s)
Devices in use: Desktop (76), Phone (11), Tablet (1)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
