ROM creation Toolbox (GNU/Linux) rev06 [2012.03.25]
Related Tags
setialpha
NĂĽrnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/27 - 20:56
So... this is all you need to create a custom ROM on GNU/Linux (using BSD / Solaris should be fine, too - just can't test). DON'T ask me about supporting Windows or Mac OS!
DOWNLOAD:
workdir.tar.xz: http://www.nanolx.org/downloads/workdir.tar.xz
CONTENT:
amdroidkitchen/ (android kitchen for linux)
apk-manager/ (apk-manager for linux)
custom-ramdisk/ + nano-boot.img-kernel (unpacked nano-boot)
custom-system/ (unpacked nano-system)
custom-recovery/ (unpacked trenano-recovery)
files/ (udev rules and adb ini)
tools/ (all tools required for modding, including fastboot and adb)
work (helper-functions)
CHANGELOG:
rev06:
update custom-ramdisk/ to rev32
update custom-system/ to rev86
add QtADB
HOW TO INSTALL:
unpack workdir.tar.xz
cd into new directory "workdir"
source work
install_x
Functions from `work' script:
  • install_x: auto-load work function and install udev rules (requires "sudo")
  • uninstall_x: revert install_x (requires "sudo")
  • repackboot: repack custom-ramdisk with kernel from image/nano-boot.img
  • repacksystem: create custom-system.img from custom-system directory [LIMIT: 120MB!]
  • repackrecovery: create custom-recovery.img from custom-recovery directory
  • repackall: all three above
  • flasboot: shortcut for `tools/fastboot flash boot custom-boot.img'
  • flashsystem: shortcut for `tools/fastboot flash system custom-system.img'
  • flashrecovery: shortcut for `tools/fastboot flash recovery custom-recovery.img'
  • flashall: all three above
  • reset: shortcut for `tools/fastboot -w' (factory reset)
  • fullreset: shortcut for `tools/fastboot -w erase recovery erase system'
  • continue: shortcut for `tools/fastboot continue' (reboot from fastboot-mode)
  • cleanup: clean the workdir
  • distributeimg: create all image files
  • distributeworkdir: create workdir.tar.xz
  • git_export: internal function called by repackboot and repacksystem
QUICKGUIDE:
BOOT: make desired changes in custom-ramdisk/ - call repackboot - done
SYSTEM: make desired changes in custom-system/ - call repacksystem - done
RECOVERY: make desired changes in custom-recovery/ - call repackrecovery - done
APK: apk-manager can do compression/decompiliation and more with apk files, run "apk-manager"
KITCHEN: run "kitchen" and follow instructions on screen.
Then just try to flash your custom ROM.
Have Fun! 🙂
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/27 - 21:14
Hi friends try this: http://www.koushikdutta.com/2010/10/porting-clockwork-recovery-to-new.html.
I am not lucky, i tried a lot of times, but it doesn't work with me, if you are better than me we could port clockworkmod on arnova and after flash zip rom and port cyanogenmod
setialpha
NĂĽrnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/27 - 21:19
I never used clockword or cyanogen - I doubt I'll have much more luck than you.
PREPARATIONS:
copy files/50-android.rules into /etc/udev/rules.d/
copy files/adb_usb.ini into $HOME/.android/
restart udev: /etc/init.d/udev restart
From now on UDEV/ADB/Fastboot correctly recognize your device.
handsomejackuk
Forum Posts: 38
2012/01/27 - 21:32
clockwork mod would be great.. any thoughts on how we can get this, or get some more help on how to get clockwork mod running, as i am comfortable with clockwork mod too...??
setialpha
NĂĽrnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/04 - 09:49
2012.02.03: rev02 is online - check first post.
2012.02.04: rev03 is online - check first post.
Thanks Received: 3170
2012/02/04 - 10:21
Very nice, thank you !
setialpha
NĂĽrnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/04 - 10:50
rev04 is ready, will upload later today (no time right now).
setialpha
NĂĽrnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/05 - 08:57
rev04 now online - check first post.
setialpha
NĂĽrnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/12 - 11:46
rev05 now online - pure awesomeness for new mods :]
setialpha
NĂĽrnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/03/25 - 21:45
rev6 now online!
morpheus972
France
Forum Posts: 11
2013/04/02 - 10:42
Hi there!
It seems that the workdir is no more available.
And now, we have the kernel source from ARNOVATECH for this tablet. Maybe it can help?
75 Guest(s)
Devices in use: Desktop (69), Phone (6)
anonymunbekannter14
dimas6086
JiotaCe
Oboronprom
vlk88
JozekPL
