2012/03/05
DanielVd said
Work in progress:
Any idea on when that'll be ready?
D.
Could one of you Devs please do a tutorial/instruction on how and which files to install and weather to put them on device or PC and install from fast boot or recovery please and how to install cwm in the first place. I find this thread a little confusing to say the least with all the different links and different instructions.
i think that this is clear enough
http://www.arctablet.com/blog/forum/arnova-7c-g2/how-to-flash-a-rom-on-arnova-1/
destructa said
DanielVd said
Work in progress:Any idea on when that'll be ready?
D.
the rom is ready on the italian forum, it remains to be updated here.
Thanks globula. I will give that one a go
2012/03/31
this is my first post in this forum. I have a 7c G2 and i would like to flash it to the DanielVD Rom. I read some topics her, but Im not shure what files I use to flash.
I have installed the ADB Fastboot and downloaded the file market.zip (in the youtube video the name is update.zip).
Then I copy the file market.zip on the sd card and start the Arnova in the ADB Fastboot. After that I type in the commands from the youtube video. After a new start, the Arnova was flashed.
Is this the right way?
What is with the file boot_mod2.zip?
I would be glad of help.
Myself
http://www.arctablet.com/blog/forum/arnova-7c-g2/how-to-flash-a-rom-on-arnova-1/ Read this and if you are not able to do`it use this
http://www.arctablet.com/blog/forum/arnova-7c-g2/need-help-to-flash-im-here-1/
hard to read the new tutorial :)) to much text
You forgot to add to the build.prop some things, and the new video drivers are not working properly
debug.sf.hw=1
debug.composition.type=gpu
ro.secure=0
windowsmgr.max_events_per_sec=280
debug.performance.tuning=1
video.accelerate.hw=1
dalvik.vm.verify-bytecode=false
dalvik.vm.dexopt-data-only=1
persist.android.strictmode=0
ro.min_pointer_dur=1
Link for the drivers
http://www.mediafire.com/?eq1fsgwm0adm0g2
You may consider to flash another firmware which integrate some fixes for the GPS: Nano CFW or Glob_Be_One
2012/06/16
ok thank you.
61 Guest(s)
Devices in use: Desktop (51), Phone (10)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
