clockwork recovery for Samsung SPH-M820: is it compatible?
tremendo
Forum Posts: 42
2012/02/07 - 00:55
i'd like to try and compile some cooked roms for our c7g2 from scratch, but before i can do it id like to do a full backup of my tablet. Has anyone tried running clockmod recovery for the samsung prevail on the c7g2? They are based on the same chipset..
**EDIT**  I meant to say
Samsung SPH-M820 ..
the recovery is in this thread http://androidforums.com/galaxy-prevail-all-things-root/390234-clockworkmod-v5-0-2-7-file-system-recovery-utility-update-01-12-12-fixed.html
tremendo
Forum Posts: 42
2012/02/07 - 03:25
in the meanwhile, i made a dump of the stock recovery partition... you can find it here http://ifile.it/5pwl2sn/recovery.img
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/07 - 09:38
Does it works on arnova?
handsomejackuk
Forum Posts: 38
2012/02/07 - 11:42
How would i use the recovery image if my tablet cocks up? Is it the case of boot into adb mode and do something. I want to know... as i keen to tryout the nano program
tremendo
Forum Posts: 42
2012/02/07 - 12:21
there apparently is a way to boot into the bootloader via adb or fastboot... but when i tried it last night it didnt work.
I've read that the phone should try booting the recovery partition if the boot part. is erased via fastboot... havent tried that yet.
danielvd: this i the recovery partition from my "stock" arnova... i dumped it via romdump .
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/07 - 14:50
When i will receive back my tablet i'll try to compile cwm for arnova
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/08 - 23:14
i am compiling cyanogenmod
handsomejackuk
Forum Posts: 38
2012/02/09 - 00:54
Great i like cyanogen. This will be gtreat for this little tablet. Do u think it will work good have you done this before.?
Which version are u compiling cm7 or cm9?
tremendo
Forum Posts: 42
2012/02/09 - 05:31
i just compiled clockwork recovery for the arnova.. havent tested it yet, might not work because i havent double checked the fstab.. anyway here it is
http://www.mediafire.com/?dorpdubo5z1cqnk
daniel, prova a bootarla mentre io faccio un altro backup di quella originale..
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 13:21
Ho il tablet in assistenza
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 18:58
Your recovery boot, but the keys are not configured 😉 te lo devo tradurre in italiano?
Image Enlarger
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/09 - 19:47
Great work. How do I unpack the recovery.img? It does not seem to be yaffs2 (atleast unyaffs fails).
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 20:06
What combination of kwys i have to press for turn on on recovery mode the tablet?
On my galaxy s is power + volume -, but on 7cg2 is the combination for fastboot O.o
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/02/09 - 20:15
err... that's exactly the problem. You have to be running Android and issue "reboot recovery".
I haven't found a combination yet. :/
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/09 - 20:26
me to, we have to fix this problem
104 Guest(s)
Devices in use: Desktop (91), Phone (13)
heftpflaster
rk.13
