2012/12/26
Hello!
I wanted to transfer data from my PC to my Arnova 7c G2 and just put the USB-cable between them. First, my device manager said "5 missing drivers for Arnova". I retried after booting the Arnova and than, my Arnova bricked in an (for me) unknown way. My device manager on PC only shows the rooter of my Arnova to me and I can't start the Arnova. If I want to charge it, it doesn't react. The screen stays black... What can I do? The tablet is unrooted.
Thanks for all ideas!
You will have to re-flash the tablet, there are already multiple guides posted, read them and you should be able to sort the tablet.
2012/12/26
The tablet isn't flashed and how should I re-flash a tablet that doesn't react to anything?!? I can't start it... It also doesn't react to charging, no light, nothing elso than a black screen...
When you connect the tablet to the PC, do you get any type of reaction ?
Let the tablet to charge for 2/3 hours using the power supply, then try to start-up the tablet by holding the power button for more then 30 seconds, or till you see a reaction.
2012/12/26
I tried already to charge it over night... But normally, the lights of the tablet are on while charging. My tablet does really nothing! Not charging, not starting...
Here is a short video: https://www.youtube.com/watch?v=1cRXOnQXt70
70 Guest(s)
Devices in use: Desktop (58), Phone (11), Tablet (1)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
