Arnova 7cG2 Rooted
duryard
Exeter, Devon, UK
Forum Posts: 66
2012/01/06 - 18:17
I dont uderstand why it worked once then not again?
I assume that I cant do the 7G2 firwamre on the 7cG2?
Not tried the z4root yet.
Tried doomlord and that does not work either.
I think its a driver problem but how do you install the drivers?
Ginger break just sat thinking about it for 30 min and I had to reset:(
alex
Forum Posts: 252
2012/01/06 - 18:30
sometimes it can take ages to work the same happened to me i used SOC and it rooted i tested it in terminal on tablet typed su and it gave me permission it then froze so i had to reset it then  the root was gone and i could not do it again... wierd
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 18:50
Having rooted the 10 G2 and the 7 G2 now I find it hard to believe Arnova would setup the firmware on the 7c G2 in a completely different way.  On both the 7 G2 and the 10 G2 /system is a cramfs file system.  A cramfs file system is READ ONLY no matter if you get SU access or not.  It would have to be a ext3 file system to be able to write to it. Since so far it looks like all the G2's have cramfs, again it would suprise me very much if the 7c G2 was truely different.
This might explain why you guys are loosing root after a reboot, locking up, etc.  DanielVD, even though you think you wrote /system it could be the rooting tool made a symbolic link to local/data or /data/system or something like that.  This also might explain on reboot stuff is gone.  Again when I first got my 10 G2 I tried using that same tool.  It said it was successful.  Alas, in truth it was not a full root.
The only way we will know for sure is to look and the init.rc file.  When one of you guys gets su access again please use a file explorer (ES File explorer will do if you don't want to pay for Root Explorer) and copy out the init.rc file that is at the root file structure /.  Post it's contents and we will have a look.
Bob
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/06 - 18:51
If you can't root do an hard reset.
Now i am working for a porting of a custom recovery, i am using a guide wirtten by the creator of clockwork recovery, i hope that it will works.
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/06 - 18:54
Bob
How can i look the contents.
I post the file: http://www.megaupload.com/?d=ATSQZSD8
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 19:05
I downloaded the file.  You copied out the wrong one.  There is init and there is init.rc
I need the init.rc file
Bob
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/06 - 19:09
Bob
ok this is the file 😉 http://www.megaupload.com/?d=ZH0Q63UK
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 19:39
OK you are correct. I was wrong... Why Arnova did something different for the 7c G2 is beyond me!
The file systems are all YAFFS2 and those can be written to!
Here is the mount commands from the init.rc file
mount yaffs2 mtd@system /system
#mount yaffs2 mtd@system /system ro remount
mount yaffs2 mtd@userdata /data nosuid nodev
mount yaffs2 mtd@persist /persist nosuid nodev
mount yaffs2 mtd@cache /cache nosuid nodev
mount yaffs2 mtd@content /content nosuid nodev
I do not know if the rooting tool commented out the read only mount of /system or if it came that way.  But it is commented out and a the mount of /system leaves it r/w
Enjoy your root!  Looks like no new ROM is needed to get r/w to /system on the 7c G2.
Bob
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/06 - 19:41
mount yaffs2 mailto:mtd@system) i hope it will works
Thanks Received: 3171
2012/01/06 - 19:43
The Arnova 7c G2 is totally different to the other G2 devices, it is based on a Qualcomm architecture, not Rockchip.
/blog/featured/arnova-7c-g2-quick-photo-review/
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 19:52
However there are some things in init.rc that would make it even better and no root tool required!
Of course these means making a new boot.img and flashing it.
For instance,
The mounting of the other partitions is nosuid and nodev.  Those could be removed.
Also after fs init, they change rootfs to ro this could be fixed.
  on post-fs
  # once everything is setup, no need to modify /
  mount rootfs rootfs / ro remount
  # We chown/chmod /data again so because mount is run as root + defaults
  chown system system /data
  chmod 0771 /data
And finally to unlock ADB this could be changed from =0 to =1
  on property:ro.secure=0
  on property:persist.service.adb.enable=0
Then finally the added comands like
  chmod 6775 su
  chmod 777 /system
Then no tool would be needed.  But the down fall is you have to flash a rom.
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 19:57
Ah OK Admin.... I did not know that.  I figured they were all rockchip.  That explains it then.
I wonder if rockchip or the 7,9,10 G2 can support yaffs2? in /system/bin I do not see yaffs like I do cramfs...  Yaffs would be better for the NAND chip as it writes data in pages and cleans up NAND well.  Yaffs is made specifically to perform well for NAND memory.
Hmmmm only one way to find out 😉
I think I will see if I can find the sources and compile it or of there is already a bin for RK29.
A project for another day....
Bob
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/06 - 20:05
For instance,
  on post-fs
  chmod 0771 /data
  chmod 6775 su
  chmod 777 /system
whit this how can i do? sorry but i am italian ...Embarassed
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 20:30
You cant without making a boot.img or a new ROM.  Even if you go in now and edit the init.rc then on next reboot it will use the init.rc from boot.img and overwrite your edits.  So you have to edit init.rc in boot.img, make a new ROM then flash it.
Problem is, Arnova has not released a update.img and no one has dumped the ROM so no way for me right now to make a new ROM for it.
Bob
Alex9000
2012/01/06 - 20:40
Bob
i am in possession of a ROM for ARNOVA 7c G2 3G ... if you can help tell me where to post it ... and i place.
Ciauz
92 Guest(s)
Devices in use: Desktop (84), Phone (8)
swan12
heftpflaster
