Arnova 7cG2 Rooted
duryard
Exeter, Devon, UK
Forum Posts: 66
2012/01/05 - 17:22
I,ve just rooted my arnova 7C g2 CoolCoolCoolCoolCoolCool
Superone click from XDA
Was a bit fiddly but you can get it to work if you tell it to force install drivers.
Looking for a recovery manager now to back up the rom etc. Got any ideas for that. CWM will not work correctly because it does not recognise the device. Same with 4ext. Both have busy box and SU permissions tho.
Thanks Received: 264
2012/01/05 - 19:43
Can you please provide the steps.
I`m new in android area but i can try some backup tools if you give me some tips.
Also you tried to instal google market ? It works ?
duryard
Exeter, Devon, UK
Forum Posts: 66
2012/01/05 - 19:59
Lost it now
Was rooted deffo.
But when I rebooted it ti try to install market its reverted back to stock and refuses to root using the same method. Damm
2012/01/05 - 20:10
you tried with the last usb drivers ?
/blog/featured/adb-driver-update-for-archos-arnova-devices/
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/05 - 20:51
it works 😉
2012/01/05 - 20:55
If it works help others and share the ways.
2012/01/05 - 21:04
I will share my way
Opened arnova 7c g2, selected debuging mode from settings
FIrst i dl the superoneclick, extecuted, after that i selected advanced and check drivers, i forced the instal of drivers (4 times i did it)
Returned to general, hit root and voila
http://www.picz.ro/pictures/c5ebccd516ea2e8f9d9b39265486b0a6.jpg
2012/01/05 - 22:05
I`ve restarted my device and the root remains
So gg me 🙂
I can instal google market but it still not working.
finless
Stanton, Ca
Forum Posts: 604
2012/01/06 - 01:27
Same thing I got on the 10 G2 with superone click BUT it was not a full root as you still could not write files to /system. So it was not a full root.
Can you check that you can make /system R/W using Root File Explorer or something please.
Bob
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/06 - 10:42
Bob
It works, you can write into system by root explorer, i copied the google apps and now works!
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/06 - 10:59
This is an how to that i wrote: http://www.megaupload.com/?d=THTKEZQ4
duryard
Exeter, Devon, UK
Forum Posts: 66
2012/01/06 - 14:31
Going to try again I think with new drivers. Also I think my version of superone click is different (does not have a version number) can you send me yours or a link please. (jeylee01@gmail.com)
When I tried previously it got stuck in bootloop at the android screen. and had to reset. was rooted tho but lost it on reboot
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/01/06 - 14:49
This is the lastest version http://www.multiupload.com/9AJDSU1Q11
duryard
Exeter, Devon, UK
Forum Posts: 66
2012/01/06 - 16:39
Got the superoneclick. Thanks Daniel. Tried again and it says I am rooted but am not so try again. Stiil will not root 🙁
Was thinking of reinstalling the firmware however I am worried that the firmware is only for 7G2?
How do you install the usb drivers?
alex
Forum Posts: 252
2012/01/06 - 18:13
yes the fw is just for the 7g2 as with most g2 alot of people cannot root them have you just tried SOC or any others eg .gingerbreak, z4root ect.?
94 Guest(s)
Devices in use: Desktop (77), Phone (17)
heftpflaster
rk.13
