Arnova 7c g2 System Image for easy unbrick
This topic is locked
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/21 - 11:55
The long waited system.img for your 7c g2 is finally here.
Download: http://www.nanolx.org/downloads/system.img
Flash:
- disconnect tablet from all cables
- power off tablet
- press power-on+volume to enter fastboot mode
- fastboot flash system system.img
- fastboot continue
Tadaa!! You're tablet should now work. See also my full-root boot.img
ng459
2012/01/21 - 11:57
Thanks for this - should keep the kids happy.
jameslewisuk
Forum Posts: 79
2012/01/21 - 12:18
Thanks very much, it worked !! 🙂 LaughLaugh
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/21 - 12:27
Can you connect to WLAN and does is the SIM-Card recognized?
There will be an update later on, the image is not 100% complete.
(issue adb shell and try to do `ls' > command not found (...))
Edit:
Found the issue: links to toolbox are missing. Will fix it.
jameslewisuk
Forum Posts: 79
2012/01/21 - 13:00
It flashed and boots fine, but....
Sim card is not recognised "please insert a sim card", when I look in "settings > about device > status" it says IMEI unknown, which I guess why it won't connect to 3g?
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/21 - 13:05
That's exactly what I meant. Today evening I'll provide a fixed one. Already got SIM Card working, but not WiFi. Luckily I bought one for my mother, too, so I can compare systems.
jameslewisuk
Forum Posts: 79
2012/01/21 - 13:25
Actually yes I am seeing both the same issues, neither wifi or 3g work.
  • 3g says insert sim card, and IMEI unknown in "settings > about device > status"
  • wifi says "obtaining IP address" and gets stuck at that point, then does not ever connect.
Looking forward to the fixed version, thanks for your help!
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/21 - 18:46
Almost finished. SIM Card/3G works. For WLAN I need to retrieve two more files and that should be it. (though this is a bit tricky).
jameslewisuk
Forum Posts: 79
2012/01/21 - 19:15
That's excellent, good work, you're fast!  I also have another fully working untouched/unmodified 7c G2 which I could use if it will be of help in any way 🙂
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/21 - 22:05
Done - download image from link above. Changes:
- fix SIM Card/3G
- added applications*:
  • facebook
  • twitter
  • es file explorer
  • chat on (Sammys* free chat application)
  • app installer (can export .apk to SD)
- WiFi works, but not out-of-the-box, here's what to do:
go to: Settings > Wireless > WLAN-Settings > press menu-button (||| on device) > Advanced > Use static IP
use the following settings:
  • IP: 192.168.1.253
  • Gateway: 192.168.1.1
  • Netmask: 255.255.255.0
  • DNS: 8.8.4.4
Those settings apply to the outermost routers (unless you changed your router's settings yourself).
Now connect to WLAN again, ét voila - it will work now.
Have Fun!
* to uninstall them use "adb root" > "adb shell" > cd /system/app/ > rm WHATEVER.apk
*Sammy = Samsung
jameslewisuk
Forum Posts: 79
2012/01/21 - 22:38
Nice one, thanks I will try this!
Do you think there is a chance of fixing WLAN fully so DHCP works normally?
Maybe this willl fix it?
1. Download from the Market 'root explorer' or a similar program. I used the free 'Super Manager' with included root file explorer. You must enable the root function in Super Manager, otherwise you don't see the folders.
2. root your Galaxy Tab --> see SuperoneClick (http://forum.xda-developers.com/showthread.php?t=803682) and theunlockr.com (http://theunlockr.com/2010/11/29/how-to-root-the-samsung-galaxy-tab/)
3. Within the file explorer you should go up to root map folder (in short: "rm").
4. Then follow the instructions of Gadgeteer81. You can either delete the file or rename it:
To Fix Android going into “Obtaining IP Address” loop:
rm /data/misc/dhcp/dhcp_list
*Edit, no good that file doesn't seem to exist??
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/21 - 23:37
No. I don't know what's wrong with DHCP. I have to do this:
enable static IP
connect WLAN
=> WLAN connection, but no outside connection
disable static IP
=> WLAN connection AND outside connection
There's definitively something wrong with dhcp. I'll maybe try wifi fixer app. AFAIK this is a pretty common issue we have here. Maybe i'll get it fixed, once Arnova shipps a full update.zip.
jameslewisuk
Forum Posts: 79
2012/01/21 - 23:42
I fixed WLAN DHCP! 🙂
I used root explorer to set the permissions to 0755 for the folder and all files in
/system/etc/dhcpcd
Not sure which file(s) had wrong permissions but it's working on my device now.
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/21 - 23:47
I almost thought it's something like that, because when you dump via ADB all permissions get lost.
I fixed many of them and created lots of symbolic links... thanks for finding it out. I'll create a new image now and will upload tomorrow (it's now 11:55 PM here).
Edit:
/system/etc/dhcpd/dhcpd-run-hooks was the file that had wrong permissions.
finless
Stanton, Ca
Forum Posts: 604
2012/01/22 - 00:03
That was a lesson I learned early on.  If you open folders and touch files in windows the permissions get jacked up and so does the owner!!!  What I do is do all my edits in windows then I put all the files in Ubuntu and do a chown and chmod to all of them.
Bob
90 Guest(s)
Devices in use: Desktop (73), Phone (17)
heftpflaster
rk.13
