ARNOVA 7C G2 STOCK ROM WITH MARKET AND ROOT
Related Tags
Thanks Received: 268
2012/02/19 - 23:25
Download Link
http://www.mediafire.com/?dg6hwvol4syqx25
Flash it from clockwork recovery, before made a wipe reset, wipe cache, wipe dalvik(advanced menu)
To get clockwork recovery watch setialpha thread or DanielVd thread.
http://www.arctablet.com/blog/forum/arnova-7c-g2/danielvd_arndroidianimoddedrom/
http://www.arctablet.com/blog/forum/arnova-7c-g2/nano-cfw-arnova7cg2/
Before open the market(go to settings, accounts and sync and tick the background data on), install root explorer, go to system app long-press Vending.apk and select "Permissions" from pop-up menu Change permissions to match all other apps in this folder (rw-r--r--)   (for me it worked without these setings but are Daniel recomandations)
Basically is a stock rom, without any other extra`s so it`s available for you, the simple user to modify how you want with programs like root tools
Has Google Market, SuperUser and Busibox
From what i tested it works with no problems
The buid was made from a stock arnova update.zip
I added superuser and busibox
DanielVD added the Market wich has most of the credits, because what i did is easy.
Hope you will enjoy.
Thx for the help DanielVD
hermes
2012/02/24 - 11:49
ufffff, i think is not easy 🙁
undefined
2012/02/26 - 21:18
after you instal the rom, you need to shut down arnova, and  get`it in fastboot mode and flash this http://www.nanolx.org/downloads/nano-boot-nosd.img
fastboot flash boot nano-boot-nosd.img
fastboot continue
the arnova will start again, and you should have a fully market experience without any download erorrs.
I can offer asisstance by Team Viewer.
chulis
Forum Posts: 12
2012/05/09 - 22:36
Is Totally necesary install new rom  to use market or is there any posibility to intall market without changing rom?  regards.
2012/05/09 - 23:29
you need to install a custom boot image and you can flash gapps (use google)
69 Guest(s)
Devices in use: Desktop (41), Phone (28)
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
hamishduke
