Link
http://arnovatech.com/support/GNU/AN7CG2_GPL_release.tgz
Having this, we should be able to compile some new roms, i will update as work is done.
morpheus972
Yes and no, on the 7C G3, the Phone function is disabled from another point (modem and firmware partition), i don`t know if on the 7c g2 is the same, or the phone function is disabled from the kernel
2012/06/23
For now, we have the source code... I just custom the kernel to try adding USB FTDI support... I just compiled the kernel...Â
Do you know how to replace the kernel, and add the required modules?
After getting the android source, and then this tablet source code, we need some script / config (such as ones for samsung... when getting android source) to build a custom rom.
2013/05/18
it is tgz file how we install it Arnova not "see" it. we must to turn it to zip i think... can you advice me?
65 Guest(s)
Devices in use: Desktop (52), Phone (13)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
