Arnova 7c G2 mod to make phone calls?
jameslewisuk
Forum Posts: 79
2012/01/22 - 21:08
I wonder, can the Arnova 7c G2 have modification to the rom to be able to make/receive phone calls?
I read about how the Htc flyer can have modification to build.prop (I think) to enable the dialler etc.
Perhaps something similar could be done, even if the hardware just worked as a speakerphone?
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/22 - 22:11
There is a corresponding line in build.prop, I'm going to check it, but there may be other things preventing this feature (missing modem stuff or similar).
setialpha
Nürnberg, Germany
Forum Posts: 209
Thanks Received: 8
2012/01/22 - 22:24
Nope. I used an external dialer-app from appslib, but it's not working, even with has_phone property set to true. Modem-Support seems not to be built-in.
If it's posible from the hardware atleast a full-fledged mod like cyanogen might make it work.
handsomejackuk
Forum Posts: 38
2012/01/26 - 21:36
thinking the same myself, my daughter has a Huawei Blaze 8510 that has same Processor... and pretty sure all the stuff is built in to the processor.. e.g. gps modem, screendriver etc....
trying to find a datasheet on the processor.. is there any way of definitely identyfying the chip...??
have a quick look at this...
http://pdadb.net/index.php?m=cpu
note there are three versions of the msm 7227... maybe the T refers to tablet...???
http://pdadb.net/index.php?m=cpu&id=a7227t&c=qualcomm_msm7227t
what does anyone think
lostpenguin
United Kingdom
2012/06/17 - 18:51
It would seem looking at the specs that the 'T' in 7227T means Turbo and not tablet. The chip certainly seems to have telephony functions and should function as a telephone if the ro.telephony lines are added to the build properties. Is this thread dormant or has someone already been successful.
Thanks Received: 264
2012/06/17 - 19:28
arnova has a msm 7627 surf processor
no succes till now whit the phone functin
84 Guest(s)
Devices in use: Desktop (77), Phone (7)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
