ArnFlasher by DanielVd
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/15 - 22:18
http://img811.imageshack.us/img811/6091/sdkx.pngImage Enlarger
Flash your arnova with this utility!
Requirements:
- http://www.oracle.com/opinions-on-teclast-p90hdchnetwork/java/javase/downloads/index.html
http://www.arctablet.com/blog/forum/arnova-7c-g2/what-is-adb-and-fastboot-how-to-install-and-use/
Link: dist.zip
Extract the program with all the files that are contained in the zip and execute from the same path
spincat
2012/02/15 - 22:34
hi, will this help the unit to work better all round? my kids have these for the last month and they are unable to get the apps they want, so having android market will be great.. my problem is we cant get movies to play.. i have converted a couple of movies on my laptop to several different formats, the ones that they say will play in the archos blurb, and none of them will play...  what am i doing wrong? i just convert to avi or mp4 and put onto the card, in the movies folder but i get a message, on both tabs to say the file cannot be played..   any suggestions would be great. thanks.
DanielVd
Forum Posts: 237
Thanks Received: 5
2012/02/15 - 22:37
This is a wrong post!
Write a new post, you can try to use rockplayer for playing films
Thanks Received: 264
2012/02/15 - 23:31
Arnova is not enough powerfull to play movies that have a hight bitrate.
A method that i used to play movies on acceptable quality was by using the app called emit(you are streaming the videos using your pc,all the files are stored also in the pc, so no movies on arnova,also the movies war re-encoded in mp4, 800-480 resolution,1500 video bitrate, 128 audio bitrate.), you can find`it in google market
2012/02/15 - 23:33
Requisiti:
- http://www.arctablet.com/blog/forum/arnova-7c-g2/what-is-adb-and-fastboot-how-to-install-and-use/
Link: dist.zip
Ok, this a good utility
For the ppl ho dont know italian, Carica means Load
Requisiti = requirments.
88 Guest(s)
Devices in use: Desktop (75), Phone (13)
swan12
heftpflaster
