Problems with WIFI
ludibubi
Forum Posts: 15
2012/07/31 - 12:00
Hi there! I installed your firmware with arctools - googleplay is working.
But I have an other problem: I want to use the internetflat of my Samsung Galaxy (G-TI7500). So I installed a tethering-app on my Galaxy, but my Tablet doesn't find this connection. With my laptop I have no problems: it detects the connection (SSID: AndroidTether), connects and I can use it. Why does the Tablet doesn't find the connection?
Regards
Ludger
Regards Ludger
Thanks Received: 3169
2012/07/31 - 16:05
It's possible that your tablet Wi-FI doesn't support ADHOC which is usually required for tethering. You can find some info about how to enable it on this post. As you can see at the end of the topic, we've added some scripts for that in Arctools that should be released later in August.
chupy
2012/07/31 - 19:04
Hello! I have the same problem with my Tablet and my nokia N8 , . No problem with the laptop but my tablet (7bG3) didnt see the connection. I will check the post you refer.
Thanks.
ludibubi
Forum Posts: 15
2012/07/31 - 22:07
:bravo:
YEAH YEAH YEAH!    I DID IT!!!!      IT'S WORKING!!!!!!!
Thanks admin for your help.
Only one question: The signal is very low although the handy lies close to the tablet. Is it a problem of the app (I use this one:
https://play.google.com/store/apps/details?id=android.tether&feature=search_result#?t=W251bGwsMSwxLDEsImFuZHJvaWQudGV0aGVyIl0. )  or of the handy?
Regards Ludger
2012/08/02 - 00:45
I don't think using Wi-FI in Adhoc mode causes any signal problem, but I can't comment much on that as I am not using it a lot myself. I know some Arnova G3 tablets (for instance the 7f G3) aren't very efficient with Wi-FI coverage, but I can't say if it's the case for the 7b G3.
ludibubi
Forum Posts: 15
2012/08/02 - 09:51
I tried several apps and always the same. So I think it's a problem of may handy. My Galaxy is the first generation.
I'm happy, that I can connect and that's the most important. Many thanks for your help. By the way: How we can get information about new custom roms?
Regards Ludger
chupy
2012/08/05 - 02:49
 hello!
I ve already done the changes in the wap-supplicant file , and im experiencing the same lo signal problem despite the devices are head to head. Ive got an old symbian based n8 and works well in notebooks and netbooks but not with the tablet.
If someone Knows why , let us know!!
119 Guest(s)
Devices in use: Desktop (102), Phone (16), Tablet (1)
offcrash
mrbit
LeonDCA
mrscharling
ebbi1978
Luis1961
Topics: 6030
Members: 261555
