Problems with Adobe Flashplayer
ludibubi
Forum Posts: 15
2012/08/04 - 08:33
I have problems with tbe flashplayer. When I access sites with flash there is only a remark' that I have to upgrade to thte latest version. But this one is installed. Now after a little bit ''googeling'' I saw that the problem is made by Adobe: the newest version doesn't work with Android ICS!
My question to the profis: is there any way to use another flashplayer, that works with the installed browser (by the way: what browser is installed on this tablet?) or any other idea???
Regards Ludger
Dolby
Forum Posts: 64
2012/08/05 - 08:55
Trie to uninstall the flash player on the tablet. Reinstall flashplayer by the Applib store or other market store. (Google store).
2x Archos Arnova 7D G3 tablets for my 2 sons.
But i have problems to get microsd working on de arnova 7D G3. Help please!
ludibubi
Forum Posts: 15
2012/08/05 - 22:51
I tried your solution without success. When the flashplayer from appslib is installed and I press "open" then the browser starts with this site: https://settingsadobe.com/flashplayer/mobile
I only see a black page with little blue symbol with questionmarks. So, in the comments of appslib I read, that everyone has problems with this  f*****g player. It seems, that adobe doesn't support Android anymore!
Regards Ludger
Dolby
Forum Posts: 64
2012/08/05 - 22:57
With version flahplayer you have installed ? My flashplayer is working without any problem.
ludibubi
Forum Posts: 15
2012/08/05 - 23:33
This one, you can download at appslib: Version 11
Regards Ludger
ludibubi
Forum Posts: 15
2012/08/26 - 14:43
Ok, I downloaded a version from 1mobile.com and this one works on the tablet.
Regards Ludger
Thanks Received: 264
2012/08/26 - 14:53
Have also on mind that adobe will not support anymore flashplayer
ludibubi
Forum Posts: 15
2012/08/26 - 15:07
Yeah I heard this too. Now the programmer must switch their sites to HTML5. When the sites don't use Flash anymore, Adobe can be forced tho do sth. And than, I think,  there are many programmer, which can program sth own for Android. It's only a question of time.
Let's see, what the future brings....
Regards Ludger
Currently Online: shtormag
81 Guest(s)
Devices in use: Desktop (65), Phone (16), Tablet (1)
shtormag
Djomla88
darkfly13
SONNY4669
borodachuk
h10101010
Topics: 6011
Members: 260691
