Topic RSS Related Topics
NEOCM10 "LEON" Jelly Bean Rom *Testing*
Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0 Topic Rating: 0 (0 votes)
2012/12/11
22:19
hpx70
Arnova 7b G3
31
While your device is in recovery mode and connected to pc, press the reset button on device, the screen will turn black and windows starts to search for rk drivers, Use the ones provided in Rockchip_Batch_Tool_v1.5. Then flash the rom as described above.
2012/12/15
08:21
heidolow
Does the kernel allow for overclocking? :)
2012/12/29
08:24
trangteen
camera not work
why show 16 bit camera ?
2012/12/29
10:57
trangteen
neomode said
For your Information a New Version is out there:
Please Download Main Rom here:
Kernel for 7bG3:
Rainer
Fix Batery update?
2012/12/29
13:18
trangteen
gamefreak61 said
Just found a battery fix that works for me.
It wouldn't install in CWM, so I did it manually.
Extract it on your computer and copy the services.jar in the system/framework directory to your SD-card.
Insert the card into the tablet and start it.
I used ES File Explorer to do this.
Give it root rights.
Then copy services.jar to /system/framework, press OK if asking to merge.
Reboot to recovery with Reboot app.
In CWM, go to Advanced.
Wipe battery stats, then press Fix Permissions.
If all goes well, battery meter works fine. (at least for me)
Work Me ,Test Pass
The following users say thank you to trangteen for this useful post:
wobbix
2013/01/05
12:23
trangteen
why Can't open  web   adf.ly
2013/01/06
07:15
mcsgeek
Forum Posts: 20
Thanks Received: 16
I am trying this rom on a 10b g3 with no luck.  It will not reboot into CWM when completing the steps.  When I force a reboot the screen is messed up like it is the wrong resolution and the touch screen won't work.  What am I missing?  Any Help?
2013/01/06
18:46
Please donate to support my work
Forum Posts: 2028
Thanks Received: 160
Online
Archos 101 XS
38
dod you flashed the rom using the rockchip tools ?
did you used restore or upgrade ?
2013/01/19
22:24
heidelfuchs
i used rockchip to flash the (latest?!?) version. I also installed the battery fix which worked like a charm for me. Everthing really looks fine and the table does become more responsive. However, I encounter frequent system freezes when waking the tablet up from deep sleep. Did I miss something or do you guys have similar issues?
Edit: Ah, well I have a 7bG3
Most Users Ever Online: 646
Currently Online: admin, globula_neagra, lolloarnova, crashogre, tjether, egbert007, nb24, nghiant015, jeff7882, Revelator, szmeron, Brnky, M.Moe, marcobus2005, Sethi, tichikawa, bazk123, TechExplorer, chidori, nemo1963, jhearrtot, blackpac, Supernova1, kelemenlajos, The_b3ier, KaraRsticStyler, validatus, wolfwood49, kurabiye, matnl, kini, kief, soulkids, ahmet_mhnds, conka, trapisantander, Nounam, baniaga.eugene, Tommy50, Erosum, ianb72, Shark_XXL, fbraine, roamanaka, jandrew
271 Guest(s)
admin: 3933
globula_neagra: 2028
Guest Posters: 39
Members: 82756
Forums: 132
Topics: 2983
Newest Members: ogibillm, ismailsha, jandrew, nopet, roamanaka, PiophyObliply
Moderators: HaroldG (117), globula_neagra (2028), exelletor (344)
Administrators: admin (3933)
